Locked markers can be moved in dopesheet with selecting keyframes with the crtl, mouse left short cut
Open, NormalPublic
Win 10, geforce 970
Broken: 2.79 5bd8ac9
Locked markers can be moved with selecting keyframes with the crtl, mouse left short cut
-> Open dope sheet
-> Add Keyframe to object (in frame 1 for example)
-> Add marker (in frame 2 for example)
-> Lock markers (select "marker" from the dopesheet´s bottom panel and select lock markers)
-> Set cursor to frame 0
-> Hower mouse at the left side of the cursor and press crtl and mouse right (selects all the keyframes from the left side of the cursor)
-> It then selects the they keyframe and the marker
-> Then you can move the marker but not unselect it without unchecking the lock markers
