Bmesh Operator "diameter" attribute is not diameter but radius
Broken: 2.79 5bd8ac9
Bmesh Operators (bmesh.ops.create_circle, bmesh.ops.create_uvsphere, bmesh.ops.create_icosphere, bmesh.ops.create_cone) using the attribute 'diameter' (and attributes 'diameter1' and 'diameter2' for bmesh.ops.create_cone) are creating meshes where 'diameter' is interpreted as radius of the mesh, meaning that the resulting diameter is twice as big.
The script "diameter_test.py" creates a mesh with the Bmesh operators with diameter 1 but having the resulting diameter 2. In diameter_test.blend is the whole scene with the generated meshes and the previous script.
Nikolai Janakiev (paramcookie) renamed this task from Bmesh Operator "diameter" attribute to Bmesh Operator "diameter" attribute is not diameter but radius.Sep 27 2017, 5:41 PM
LazyDodo (LazyDodo) triaged this task as Confirmed, Medium priority.Sep 28 2017, 5:39 PM
I can confirm the issue, however fixing it by either renaming the parameter or changing the way the geometry gets generated in bmo_primitive.c would cause quite some breaking for everyone (which i guess we could do for 2.8). not sure what the best way forward is here, paging @Sergey Sharybin (sergey) for guidance.
