Crash when removing second material slot from data-linked objects #52953
6 Participants
Reference: blender/blender#52953
Win7 64bit ATI HD4670
Broken: 2.79
If you Alt-D duplicate many objects and create second slot for material in one of them, then Blender will crash after atempting to remove it.
Open file, remove second slot.
Crash_mat_slot.blend
Added subscriber: @SergeL
Added subscriber: @LazyDodo
id has a bogus pointer at
Added subscriber: @RainerTrummer
It must be buried somewhere in the code that handles the material link type (i.e. if it is set to 'OBJECT' or 'DATA'). In the given file, the material link is set to 'OBJECT'. If you set the link to 'DATA'on all cube instances, the slot can be removed without a crash. I have done that material link change in the file provided here:
No_Crash_mat_slot.blend
It's the same file as in the initial bug report, just the link type has been changed. However, it is not sufficient to only do the change on one cube instance. In that case, the crash would still happen.
We're also using 'OBJECT' link type here in the studio a lot, so we rammed into a similar issue today. The 'solution' is identical. Hope this helps to track down the bug.
Added subscriber: @ChingPingSun
By simplifying the original file, I reduce them to 2 objects, and add another 2 objects for comparison.
In the attached file (test_case_2.blend), the left side 2 cubes, will cause crash. While the right side 2 cubes won't.
It would be helpful to know HOW those cubes are created ? test_case_2.blend
Comment: The crash was also happened on macOS, system information:
macOS 10.13.2
Broken: 2.79, 2.80(2017-11-25)
It doesn't crash with Data option, only Object
I changed the right side cubes to Object, then Alt-D to duplicate, after that, deleting does not crash.
While the left side cubes will.
So, I am curious about how did you create the left cubes ?
Please see the attached : test_case_3.blend{F1522174}
I did same thing, Alt-D cube with one Object material many times, than add another slot to one cube (others will not have second slot).
Here is yours altered file:
test_case_3_altered.blend
OK, we get some observations now:
There is a strange place in the code, it seems that the active current material index is not decremented (when it should be).
Attached is the patch, It only passed the crash test, not sure for that it is a correct fix, is there anybody can{F1586868} help to review?
This issue was referenced by
0becc8a7dd
