Curve Simplify uses wrong dimensions #52973
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#52973
eOS 0.4.1, GTX980ti
Broken: 2.79,1, e8a0812a3b
Simplify Curves (release/scripts/addons/curve_simplify.py) is a nice addon that comes in handy for example when you want to simplify a 3D Curve that you generated from a Grease Pencil curve. However, it seems to fail to assign the correct curve dimensions. After using the Simplify Curve operator on a curve, it first looks correct, but once you go into edit mode it jumps to a different location and shape. I think it is because the addon doesn't make the curve a 3D curve, but keeps it as a 2D Shape. When I make it a 3D Shape before going into edit mode it works just fine. I have a patch for the addon which seems to fix it, because this seems to be the intended behavior.
curve_simplify.diff
Open the attached blendfile. There is a curve which was generated by converting a grease pencil stroke to a curve and after that running the Simplify Curves addon. It seems to be a 3dimenional object, even though the curve data shows it is a 2D shape. Now press Tab. The curve becomes a flat shape. If you undo that, make the curve a 3D shape and hit Tab again, it works fine.
curve_simplify_dimensions.blend
Added subscriber: @sebastian_k
Added subscriber: @VukGardasevic
I'll look into it.
This issue was referenced by
dfdf55714c
