Incomprehensive words found in translation file
I found the following lines in vi.po,
line number 115820
#: source/blender/editors/space_outliner/outliner_tree.c:1068
msgid "Strip None"
line number 115828
#: source/blender/editors/space_outliner/outliner_tree.c:1226
msgid "Modal map, not yet"
and they are found in the MASSIVE function:
static TreeElement *outliner_add_element(SpaceOops *soops, ListBase *lb, void *idv,
                                         TreeElement *parent, short type, short index)
Without the understanding of the actual technical details, I have no idea how these words are used. All I know is the
msgid "Strip None"
refers to a sequence strip element type (TSE - Tree Store Element), mentioned in the DNA_outliner_types.h. Is the word 'None' here refers to the state of 'Not a strip' ? or 'A strip without a body'?
The second one:
refers to TSE_KEYMAP_ITEM, that is the keyboard mapping (shortcuts), I think. The Modal Map refers to the 'mapping of modal' type, what is the word 'not yet' here really meant? Does it mean 'Not yet fully realized' - ie. not properly formed' - or what?
There is also a very technical message as well, but fortunately, it doesn't appear in the vi.po file. It refers to the size of the datatype - ie. the number of bytes the compiler allocates for the data type, (Long vs Short), and it means the data type, for some unknown reasons, has changed its size.
BLI_STATIC_ASSERT(sizeof(te->index) == 2, "Index is no longer short!");
Can you please help me verify the actual meanings of those sentences?
Kind regards
Hoang Tran
