Added Faces on Array Modifier #52976
Reference: blender/blender#52976
Windows 10 Build 15063.608
2.79
5bd8ac9
Array modifier adding face that does not exist.
Open the attached "tunnel.blend" file. Should open on array modifier. Change count from 2 to 3. Note upper left and lower right areas of viewport - extra face is added that has no vertices. It renders that way. It cannot be selected as it does not exist; no defined faces or vertices to work with.tunnel.blend
Added subscriber: @CMalcheski
Added subscriber: @zeauro
Problem comes from original geometry.
At starting point, there is an ugly Ngon which can only be made with degenerated triangles.
If you move up a little bit long edge at the bottom of the Ngon. Same chaotic interpolation is visible on original mesh.
I don't know why array modifier only revealed it at count equal 3.
But you just have to make an acceptable Ngon without degenerated triangles and everything will be fine.
Added subscribers: @ideasman42, @Sergey
Here is a simplified version: tunnel_simple.blend
@ideasman42, do we consider this a bug in tessellation code?
The ngon is degenerate - hint.
if you select a face and grab it notice it flickers, this is a sign that its degenerate and only gives correct results sometimes (by accident).
