N key doesn't open N-panel in tight space #52979
5 Participants
Reference: blender/blender#52979
Win7 64bit, screen resolution 1352*697 px
Broken: 2.79
N key doesn't work until manually click on tiny plus sign, after that it works good.
untitled.blend
Added subscriber: @SergeL
Added subscriber: @VukGardasevic
If the area is made wider (by dragging the border) than the default width of T and N regions in pixels - they will be displayed.
Also, they will show if the T and N regions were previously resized to fit the width of the area.
There is some difference in how with
+ sign
those act compared to using shortcuts - so the report is about making them uniform?@JulianEisel should this be considered as a ToDo since the similar behavior is there for a long time?
Added subscriber: @KonstantinsVisnevskis
Could be called a minor headache but this sometimes does lead to confusion and thinking that keyboard button isn't working or something like that (had been banging it a few times :) ). "Instinctively" one often assumes that the panel will get reduced in size to available space or would even get displayed in any way possible rather than not show up at all. Especially problematic when opening a project saved on a big monitor on a smaller computer. Makes one wonder why suddenly all the panes "stopped working".
@VukGardasevic "If the area is made wider (by dragging the border) than the default width of T and N regions in pixels - they will be displayed." At least in 2.79 and before this seems not to be the case. If the n-panel in the viewport is scaled up and the viewport is reduced in size after, it won't show up regardless if there is space for the default size.
There is a difference between the first shortcut run and the consequent ones after resize of the Regions.
Basically if the regions were not resized in width to fit it'll try to open up the default one and get collapsed if the area is too small.
It is possible that I didn't fully understood what you mean, so I'll describe my thought in detail:
Wouldn't it be logical that in this situation the panel would be scaled down back to default instead of not showing up?
(I mean only the situations when the user explicitly presses T/N shortcut of course)
Added subscriber: @AnthonyEdlin
This is a long standing issue with design of areas and regions. There are many ways you can get the regions to force hide and therefore get it so that opening the region will fail with shortcuts. Scaling window like you said is just one.
It isn't even consistent in behavior.
For example, you can simply shrink 3d area with both N and T regions open and N region will close once they cross over each other. Now press T to close the tools region. N region will open up because it now has room, and you would think that the T region wouldn't open if you pressed T again because now it doesn't have room, that would be consistent with how you described the issue. But instead, the T region does open up and it force closes the N region again. This is because in the code the T region just happens to come first in the list of regions and therefore get's priority. In the image editor the T region comes after the N region so it works the opposite way.
Another example it isn't consistent is that if a region is hidden and wouldn't fit into the entire area's available space when shown, if you click the plus button on screen instead of the shortcut key it will actually resize the region to fit in the space available. This doesn't work if the region will not fit in the remaining space, only if it doesn't fit in the whole area's available space.
Very confusing to users if you don't understand internal data structures.
Added subscriber: @brecht
Should be fixed by
822c67364e
