FFmpeg unpremultiply 2.79 #52988
6 Participants
Reference: blender/blender#52988
WIn10 GTX980Ti
2.79bd8ac9
When OpenGL render, alpha processing when saving with FFmpeg differs between 2.78 and 2.79.
It is not Unpremultiply 2.79.
Add Background images > Draw Front > Opacity to lower > OpenGL render Animation(FFmpeg Video/2.78 H.264) save
Added subscriber: @KNAO
#53543 was marked as duplicate of this issue
Added subscriber: @Sergey
After studying own file about this issue came to conclusion that the current behavior is more correct. What was happening in 2.78 is:
There is no correct way to apply color space conversion on a buffer with alpha, so our approximation was causing some brightening on colors.
What happens in 2.79 is:
This was done as an optimization (to avoid byte->float->byte roundtrip), and since there is no color space conversion and alpha transform involved, there is no brightening involved either.
So while new behavior is different from 2.78, it should match exactly to what you see in viewport, what you see in OpenGL render result and what you see in the generated file. If that's not the case, please attach demo .blend file which demonstrates the issue.
I tested it again.
I am sorry It seems to be a problem of the preservation process rather than the problem of OpenGL render.
I tried to save it with RGB and RGBA with PNG easy to understand.
As with FFmpeg, alpha processing is not appropriate when saving RGB.
RGBA save
RGB save
RGBA save>Nuke>RGB save(This is the best)
Screen shot
test.blend
Added subscriber: @brecht
Ok, see what happens now.
What happens is: saving image with alpha channel will alpha-over it on top of black background. This was added in
47d6d18771
, and the reasoning here is following: if buffer has premultiplied alpha, we can't just ignore alpha channel, since that would cause colors to burn in areas where alpha is less than 1.However, for unpremultiplied alpha images (such as OpenGL render) it's not really needed to alpha-over on top of black, and perhaps simple ignore of alpha channel is what we should do. Here is a quick patch for that:
P535: Fix #52988
@brecht, wouldn't mind having second opinion here.
I think that fix makes sense. It's really a matter of different interpretations of alpha. With straight alpha you kind of assume that you have a full RGB image and then the alpha is a mask on top of that. In that case a user might expect to be able to recover the original image without the alpha mask. With premultiplied alpa images like renders it's not so much a mask that was applied after but rather there being no light there in the first place.
For straight alpha images, alpha-over on top of a black background is exactly the same operation as converting from straight to premultiplied and then dropping the alpha. For premultiplied float images,
IMB_alpha_under_color_float()
does not do much since it's already premultiplied, except setting alpha to 1 and setting the RGB to 0 when alpha is 0 (which I think is wrong actually).@brecht, hrm actually after more testing i'm not sure what is really expected here.
For example, consider such input RGBA image:
Before this patch saving it as RGB will give you:
Which is quite expected i guess. At least that was an intention of the commit mentioned above. This is how Gimp will behave when you try to remove Alpha channel from RGBA image (it alpha-overs image onto a background color).
But with this patch you'll have:
Which is quite useless i think.
Black is a bit arbitrary, so maybe alpha-over on white will be better alternative? Or.. a toggle whether to alpha-over or simply kick alpha out?
Honestly, I think leaving the behavior the same as it is now is quite acceptable. If you're going to render an OpenGL preview with a semi-transparent background image, you can't expect the result to be the same as if it was opaque. With Blender 2.8 and Eevee you'll be able to set up a world background image, and render out the animation with Eevee. Semi-transparent background images for viewport modelling are a separate thing then.
If you save an RGBA image as RGB, you need to composite it over some background color, and in general we can't guess which one the user wants. Black is as good a default as any in my opinion, white is going to look bad in other cases. We could add an option to choose the color, but maybe that's better left to the compositor.
There is no problem saving RGBA.
But for RGB save alpha should be ignored.
"Channels of the image to draw: Color"
It is so with display switching. In the case of RGB Is something wrong with what I want to save with this?
Also, even if you make the background Sky with OpenGL render, translucent alpha will be reflected, so even if you forcibly try to lose alpha it can not be avoided.
Added subscribers: @davidmcsween, @chrisloughnane
When ffmpeg is first selected for output, there is no alpha channel available in output options.
In fact the color state boxes BW or RGB are not selected at all, the panel then defaults to RGBA (which isn't even an option button).
When the VSE is used to output this can result in an animation that uses alpha images over a VSE neutral background, the premultiply process is not applied.
I understand that no premult is desired (for alpha image sequence output), but I think that the default ffmpeg setting in 2.79 should at least be in RGB only mode.
After extra thoughts i would consider this more a TODO. There is really no way to solve this issue when OpenGL operates in straight alpha mode. Any decision here will be arbitrary, and will solve one usecase but will ruing another one.
Proper solution would be to switch OpenGL to work with premultiplied alpha, which might still happen in 2.8 project.
Added subscriber: @1017965668
