2.79 Add 'copy array' for rna bug in Constraint ( Rigid Body Joint )
Open, ConfirmedPublic
i want just to set the pivot location of ( rigid body joint ) constraint fast to specific place.. liek to 3D cursor.. but cant copy the entire vector with the new feature CTRL + ALT + C or V
how can i build robots very accurate in BGE if its so hard to set the pivot accurate ??????? PLEASE fix it
already : )
ronan ducluzeau (zeauro) triaged this task as Confirmed priority.
I can confirm the problem.
If I try inversed action to copy pivot offset array of rigid body joint constraint to another location array, I have an error message.
Paste expected 4 numbers, formatted: '[n, n, n, n]'
There is an UI inconsistency, here. The constraint shows an array of only 3 values.
