DXF import for a file exported from QGIS fails with IndexError: list index out of range #53094
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#53094
Broken: 2.79 release 5bd8ac9
Importing a DXF file exported from QGIS fails with following exception.
Same DXF opens in Autodesk DWG TrueView 2018. It is a pretty simple map with a few areas.
Enable DXF import.
Import the attached file.
oulu-alueet-terveyysasemat.dxf
Added subscriber: @antont
Added subscribers: @cnd, @mont29, @Sergey
@cnd, is that something up to you? @mont29, you als oseems to be mentioned as a maintainer :)
added an if statement to make sure the width property of dxf entities can be accessed as a 2dim array.
[can't remember how to link commits... ]
5f8aaa2d4e
Also, you can use "center geometry to scene" option and leave away "merge objects" option in your case.
