get selected bone in blender python is inconsistent #53135
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#53135
Win 7 64 bits
official 2.79
hash 5bd8ac9
When I print the selected bone in python, the result is wrong when a command switch back and force to pose mode.
New blend file
create a bone, go to edit mode
extrude a few times (let's say 8)
select the first bone.
launch this script a few times :
import bpy
C = bpy.context
selBone = C.selected_bones[0]
print (selBone)
bpy.ops.object.mode_set(mode='POSE')
bpy.ops.object.mode_set(mode='EDIT')
print (selBone)
sometimes console will print "Bone" and sometimes "Bone.008"
I found this bug using the addon "Auto Bone Controller" which crashed when doing funny things in pose mode and edit mode.
Added subscriber: @sarazinjean-francois
Added subscriber: @JoshuaLeung
This is an unavoidable dangling pointers/references bug that we cannot ever fully fix:
selBone = C.selected_bones- [x]
line grabs a reference to an EditBone. This then gets invalidated on the first mode-change. Python has no way to know this of course, and we can't really do anything about this (at least not without significant slowdowns)To fix these problems, don't hang on to pointers to data before/after mode changes. Instead, store the name of the bone instead, and look up the new bone instance using that name.
For example, your script should be changed to look more like:
Hope that helps
thanks a lot Joshua. I wasn't aware that getting a selection was a pointer. I'll try to propose a change to the addon with the work around you proposed.
