Replace os.system() with subprocess.check_call() #53210
Reference: blender/blender#53210
Change all instances of
os.system()
that do not need to go through the shell to usesubprocess.check_call()
instead. Not only does this save a process creation, it is also safer, with less chance of being tripped up by filenames with odd characters in them.ldo-use-subprocess-20171031.patch
Added subscriber: @ldo
Added subscriber: @mont29
Thanks for the patch, but there are two problems here:
& co are not latest recommended stuff, since py3.5 you havesubprocess.run()
which is new recommended high-level API to be used.Also, please create a differential, it’s correct way to submit patches now. :)
We appreciate the effort, but am going to close that task, if you really think getting rid of
os.system()
calls is that important please resubmit to correct place with latest API usage, and avoid mixing totally different areas of code base in the same diff. ;)subprocess.run()
was not appropriate for any of them. It returns an object for separate extraction of output, status etc, which is not needed in any of the cases I replaced.Updated patch:
ldo-use-subprocess-20171217.patch
Added subscriber: @LazyDodo
it's still preferred you post it as a differential
OK D2967
