UI/UX implement per engine material outputs #53214
Reference: blender/blender#53214
In most cases, users will use the same material for multiple engines (e.g., Eevee and Cycles).
However, in some cases users should be able to have different Output nodes in the same material datablock, so that different engines can have different nodes. We need to figure out how we will expose that to the users.
The current proposal is to refine the behaviour of the active output node :
You can read the original discussion here: https://lists.blender.org/pipermail/bf-viewport/2017-June/000314.html
Added subscribers: @dfelinto, @fclem, @brecht, @JonathanWilliamson, @pablovazquez
To be sure I follow, the current proposal is to support a single Output node, with it outputting the correct data per engine behind the scenes? Such that the user doesn't have to change anything?
@JonathanWilliamson You got it wrong.
In 2.79 if you have multiple output nodes, Blender would use the last selected one. This is the "active output node", and it's stored per material I think.
In 2.80 the proposal is to still support multiple output nodes, and have the last selected one as the active. However, instead of storing it per material, we would stored it per material, per engine.
So that the same material can have a different "active output node" for Cycles and for Eevee.
One thing that is a common issue in theses cases, is to determine which engine to use at a given time. Should it be the scene one, or the workspace one? Same goes for when creating a new material and clicking on "Use nodes".
When trying to add a new node is a bit different because we can allow the "poll" to accept both.
I understand now. Thanks. That seems to make more sense as well.
Seems to me this would default to the workspace, since most shading workflows would have either Cycles or Eevee as the final output and the view engine.
It could get tricky quickly...
Personally I would like to get rid of the "active output node" mechanism. It's really quite confusing and against Blender conventions that selection influences a final render. If it needs to say I think it needs to be controlled by a checkbox on the node instead of by selection.
I think that if there is an engine specific output node, the engine should use that. If there is no such node, the engine can find one that it supports, so Eevee and Cycles would use each others output nodes in that case. If there are multiple output nodes of a given node type, then all but one can be greyed out and never used be any engine. I don't think anything needs to be explicitly stored per engine, just per node type would be enough.
+1
To clarify your proposal, we would have:
Then we have the following scenarios:
I like this idea. But I think we may also need to clearly indicate which Output node will be used (for workspace and/or scene?) in scenario (2), not only in (3).
I would just ensure the output node name contains the engine. If the workspace and scene engines are different, or if using multiple workspaces, it's not so obvious what some node being highlighted in the node editor means.
