Parented Rigid Body offsets on transform if the parent has been moved
Confirmed, NormalPublicKNOWN ISSUE
Win8.1, 3x gtx580
2.79
If a rigid body is parented to something (like an empty for group animation before beginning of the simulation etc.), if the parent was moved or animated, when attempting to transform the rigid body, it begins transformation with the offset of the parent (makes it impossible to fine tune simulation starting locations).
This happens when animation frame is within simulation range +1.
  • Press G (grab transform) or use transform widget on the selected plane.
If the rigid body gets re-parented, the offset disappears until the parent is moved.
Have you tried using bones ?
They are far better for finetuning relations between objects in animations.
Parent-child is normally not used for finetune tweaking positions between regular objects.
Another option is to use shapekeys, in edit mode but thats also not commonly used.
Shapekeys are there when bones would be to complex to use.
Parent-child is not being used for fine tuning. The problem described above is to move objects individually, not the parent.
ronan ducluzeau (zeauro) lowered the priority of this task from 90 to 50.Nov 4 2017, 12:38 PM
For .blend example, you can temporarily disable rigid body world in Scene tab to adjust your object.
But I am not sure that would be acceptable for a bigger scene with lots of objects to adapt at different frames.
Well, as a work-around that sounds better than what I did - re-parenting the objects being worked on at every key frame :)
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Known Issue".Feb 10 2020, 5:08 PM
