VSE proxy anomalies
System Version: macOS 10.12.6 (16G1036)
Intel HD Graphics 4000:
Chipset Model:	Intel HD Graphics 4000
Type:	GPU
Bus:	Built-In
VRAM (Dynamic, Max):	1536 MB
Vendor:	Intel (0x8086)
Device ID:	0x0166
Revision ID:	0x0009
Automatic Graphics Switching:	Supported
gMux Version:	1.9.23
Metal:	Supported
NVIDIA GeForce GT 650M:
Chipset Model:	NVIDIA GeForce GT 650M
Type:	GPU
Bus:	PCIe
PCIe Lane Width:	x8
VRAM (Total):	512 MB
Vendor:	NVIDIA (0x10de)
Device ID:	0x0fd5
Revision ID:	0x00a2
ROM Revision:	3682
Metal:	Supported
Displays:
Color LCD:
Display Type:	LCD
Resolution:	1440 x 900
Pixel Depth:	32-Bit Color (ARGB8888)
Main Display:	Yes
Mirror:	Off
Online:	Yes
Rotation:	Supported
Automatically Adjust Brightness:	No
Display:
Resolution:	1920 x 1080 @ 60 Hz
Display Serial Number:	948700386
Mirror:	Off
Online:	Yes
Rotation:	Supported
Version 2.79 (2.79 2017-09-11, Blender Foundation)
After creating proxy in VSE .. blender is not playing back the correct frame rate ..
It jumps around especially on proxy rate of 50% or 75% ..
  1. Dragged in 48FPS gopro made video
  2. create proxy with "rebuild proxy and timecode indices"
  3. Select proxy 50%
  4. Playback video ..
Frames skip fps .. wavers ..
Philipp Oeser (lichtwerk) triaged this task as Incomplete priority.Jan 4 2018, 5:22 PM
Sorry for late answer on this one, but I am getting pretty much the behaviour I would expect.
That is: degrading performance when upping the proxy resolution.
On my laptop I can play your file:
  • proxied at 25% at full 48fps
  • proxied at 50% at full 48fps
  • proxied at 75% at something juming around at ~35fps
  • unproxied at varying fps with skipping frames etc.
I wont argue that a better performance is always desired, but:
Are you getting less performance on a proxy of lower resolution compared to a higher?
Maybe I am misunderstanding something but a proxy is not guaranteed to give 48fps, right?
I could be wrong here, if so, try to be specific at what you would expect blender to do here...
Philipp Oeser (lichtwerk) closed this task as Archived.Jan 12 2018, 8:19 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
