Dupli-verts/dupli-faces not working.
Broken: 1b18e15802 (also on facdc15fdd)
Dupli-verts or dupli-faces not working.
  • Parent lamp to default cube, set cube Duplication to Verts.
Or open this 2.79 file that has a torus in each of the (vertex-only) cube vertices:
Dalai Felinto (dfelinto) triaged this task as Confirmed priority.
@Sergey Sharybin (sergey) do you know if this is a depsgraph issue?
Nevermind, that's on me.
Problem still exists for Cycles
Cycles is considering all dupli objects as _dupli_child_original, and need to be hidden.
But since the other engines dont hide the dupli child orininal, I dont know why Cycles have to be different.
Maybe the original child should be hidden only with the F12 rendering?
See object_render_hide from blender_object.cpp
