Blender ID add-on: $HOME/.netrc breaks authenticated requests #53288
legacy project
Infrastructure: blender.org
legacy project
Infrastructure: Websites
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
1 Participants
Reference: infrastructure/blender-id#53288
This is an issue with the requests library. As a result of this issue, the Blender ID add-on cannot send an
Authorization: Bearer xxxx
HTTP header when the user has a$HOME/.netrc
file.A possible workaround is to pass
trust_env=False
. However, this also removes the ability to set the HTTP proxy through environment variables. I think for now the best is to check for the existence of$HOME/.netrc
and warn the user through the add-on preferences panel.Changed status to: 'Open'
Added subscriber: @dr.sybren
Closed as duplicate of blender/blender-addons#52771
