API Image Operator bpy.ops.image.open - Segmentation Fault #53294
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#53294
Kernel : Linux 4.10.0-38-lowlatency (x86_64)
Compiled : #42-Ubuntu SMP PREEMPT Tue Oct 10 14:33:03 UTC 2017
C Library : GNU C Library version (Ubuntu GLIBC 2.24-9ubuntu2.2) 2.24 (unstable)
Default C Compiler : GNU C Compiler version 6.3.0 20170406 (Ubuntu 6.3.0-12ubuntu2)
Distribution : Ubuntu 17.04
Graphics Card: Onboard
Broken:
Worked:
Segmentation fault when calling bpy API image operation "open" with any image file. This also cripples the NetRender addon.
bpy.ops.image.open(filepath=filename)
I'm going to attach a sample python script that will cause the crash, in addition to a simple bash script that will use each of the three mentioned versions of blender, to show that only 2.78c official release works.
Attached here are the script files I used to reproduce the error
This is a simple bash script, which will call blender several times; Once per specified version. The release folder must be in the same folder if you want to actually use it.
cause-crash
This is the python script that fails on the two newer versions, but succeeds on official release 2.78c. It expects an input file called "test.exr" in the same directory, and will output "test.jpg" on success. I'm currently using it with an EXR generated by the NetRender addon. I can upload my test EXR I'm using if you like, but it also fails with any PNG I stick in there as well.
cause-crash.py
Here is output generated when I ran the script myself
log.txt
Here is the blender crash log generated from blender-2.79-21a535840df-linux-glibc219-x86_64
blender.crash.txt
Added subscriber: @mikeperalta
blender/blender#53446 was marked as duplicate of this issue
This comment was removed by @mikeperalta
This issue was referenced by blender/blender@5b3c15e336
Added subscribers: @meetar, @LazyDodo
Added subscriber: @ideasman42
note: better to use
bpy.data.images.load
