Currently notifiers types are hard coded, where listeners make assumptions about the content each region shows.
This fails when the contents of a window is defined by add-ons, or defined dynamically.
Typical cases are:
- Add-ons expose buttons for properties not accessed by default for those regions.
- Manipulators in the view-port may control properties which users will expect to be refreshed when changed elsewhere (2.8 only).
I'm proposing to update this system with a dynamic and more general system using the publish-subscribe pattern.
This task was prompted by manipulators not responding updates to changes elsewhere, currently there are many noticeable glitches.
Process Overview
- As the interface is constricted (manipulators and properties), the region subscribes to changes from the properties.
- Upon modification, changes to the property are published. (RNA property update)
- Subscribers are notified of the change (their callbacks are executed).
- RNA properties will be one type of message, we may want to use this system for listening to other kinds of changes (listening to file-system message for example).
I expect RNA property messages cover most cases, keeping option open to have other kinds of messages just helps to be future proof.
- There is some overlap with bpy.app.handlers since it should be possible to listen to changes to Scene.frame_current which is similar to frame_change_post handler.
The difference is this system is intended for refreshing the interface after a change - and they should never make destructive changes, also - unlike bpy.app.handlers you wont have pre/post conditions.
- It's not well defined how granular publish/subscribe messages should be.
- Only publishing changes from ID data-blocks is too course.
- Publishing changes to individual vertices is too fine grained.
I'd suggest to make array-elements an exception, where an (ID-data-block + mesh-vertex-property) pair could be used, avoiding the issue of treating each vertex separately.
There is still some areas that aren't well defined: how should we handle modifiers or fcurve properties for example as a single unit, or handle each property separately.
This can be changed as we go, so I'm not too worried about this.
- It may be useful for Python to be able to subscribe to messages too.
There is nothing to prevent this from being supported, however it's not part of this initial proposal.
Challenges
- Performance: keeping the overhead of maintaining the messages low.
Each full-redraw will create a set of data to listen out for - which need to be stored for fast matching in the case a change is made.
I'm mostly concerned with the overhead of allocation, hashing and de-duplicating.
This may not end up being slower overall than our current notifier system, which redraws often *just-incase* a change elsewhere is needed.
Nevertheless there is a difference with the old notifier system, where the inefficiencies happen when listening to changes instead of when drawing buttons and manipulators.
- Migrating from the existing notifier system.
This will be kept in-place initially, we should be able to phase it out.
- Exactly how the 3D view should subscribe to changes from mesh/lamp... etc.
We may end up needing to listen to changes on a per-datablock level in this case.
Even then - if there are 1000 objects in the view. Would this add 1000 listeners on each redraw?
Suggest in this case we don't attempt to track individual ID's the draw-manager for each 3D view can listen to a fixed set of properties with PointerRNA.id.data set to NULL, with the down-side that changes to an object will cause a redraw even if it's not in the view.
This is at least no worse than the current system.
- As with the current notifier system, we'll need to make sure stale data is cleared.
