Black render artifact with CPU+GPU rendering in viewport #53324
7 Participants
Reference: blender/blender#53324
Windows 7 Pro
Nvidia Quadro P6000
Intel Xeon E5-2690 v4
Broken: daily builds 2.79 since at least 25.10.2017.
Worked: -
If I enable combined CPU+GPU rendering, a black rectangle shows up on one of my objects. It shows up in viewport rendering, and also in the final render. This seems to be independent of the material used. I have provided a stripped down version of the scene where it is still visible. This time only in the viewport, the final render works for this simplified scene.
The artifact seems to be "locked in space", I can move or rotate the object away, so that it disappears. In some rotation angles it is not a black rectangle, but dense black lines.
What is also interesting is that the surface of the object in not only black, but partly transparent. I have put a lamp and a cube inside the object in the demo scene, these should not be visible from outside, but they are.
black_artifact_bug3.blend
Added subscriber: @ZsoltStefan
#73424 was marked as duplicate of this issue
Added subscriber: @zeauro
Here, problem appears with GPU only too.
If origin of the object is moved to center of geometry, problem is solved.
It looks like a duplicate bugreport of this #4835 that became a ToDo.
Added subscriber: @brecht
Confirmed the artifacts, needs some investigation to figure out if this is a to do or new unknown case.
I would like to confirm that this bug is still present in Blender. Just checked with the example file and the 2.80 build from today.
Added subscriber: @mano-wii
I can confirm with OpenCL.
It has to do with the position of the object.
Here a simplified file:
cycles_gpu_bug.blend
Added subscribers: @kurtloeffler, @ideasman42
This issue is resolved and I cannot reproduce it anymore with Blender 4.1 and both CPU and GPU (HIP) rendering.
