Blender crashes when trying to right-click the wire frame or outside the wire frame #53326
Reference: blender/blender#53326
Windows 10 Intel Intuos
Broken: 2.79
Worked: Worked a while ago
Whenever I right-click on a wire frame or outside the wire frame (this happens with the quick effects), it crashes.
Open Blender, right click the default cube, go to object (text not icon), hover over quick effects, click on quick smoke, right-click the wire frame for the smoke domain or right click outside the wire frame, but in the 3D editor.
Added subscriber: @TheLordofAnimation
Added subscriber: @zeauro
I was not able to reproduce the crash.
Thanks for the report but it would be helpful if you add a blend-file to the report that demonstrates the issue at hand.
Ideally, a .blend file where we just had to click to produce the crash.
Does it occur only with smoke domain or any object that have its display maximum type set to Wire ?
Please:
Give us your exact GPU (including drivers) versions, as requested in the template!
Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker).
Try the latest build from our buildbot .
Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
Launch Blender from the command line with -d option and attach as text file here any error printed out in the console (do not paste it directly in comment).
Try to run Blender through Software OpenGL, this will be much slower however, if everything works then it means that the bug is spefic for your GPU/Driver and you should report the bug to your GPU vendor instead.
On MS-Windows: Download this dll and copying it so its located in the same directory as 'blender.exe' and run Blender normally.
Added subscriber: @fablefox
Hi,
Try running in debug mode, or better yet, pipe the result to text.
blender -d
or
blender -d > debug.txt
In case it crashed and there is debug information in the debug.txt, please upload it here.
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
