Text Object - Edit Mode - Special Characters - Circle and Promille doesn't get created
Open, Confirmed, LowPublic
Nivida 760 GTX, Win 7, 64 Bit, german
Broken: (example: 2.69.7 4b206af, see splash screen)
Blender 2.79
Text Object - Edit Mode - Special Characters, the Special characters Circle and Promille doesn't get created when i choose them.
Create a new scene. Create a text object. Insert special character promille, insert special character circle.
They should create. But here nothing happens then. There is no warning. The Info editor tells me the characters are created. But the characters are simply missing in the text.
The list in the Info editor seems also to have some flaws at displaying what character gets created. Two characters shows an empty string in the brackets. One shows the common square for a not found ascii character.
Maybe this is because of my german Windows 7 64 Bit Home , with american keyboard layout removed.
Example images and a file is attached.
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Confirmed, Low.
Those are missing chars in default Blender font.
Note that pro-millage is easy to get from any most main fonts (dejavu, gentium, etc.), circle char seems much less common…
Anyway, will see if I find some time to add those in our embedded font, would not consider this any high priority though.
