Keyframes on particle system settings
Closed, InvalidPublic
iMac with MacOS 10.13.1
ATI Radeon HD 6970M graphics
Broken: 2.79
When working with particle systems, it is impossible to keyframe the values in the particle settings. They will be marked as keyframed (with coloured text fields), but when you input a new value, it immediately jumps resets to it's old value. Tried this on different Macs, I don't have access to a Windows machine.
In the attached blend file, try to keyframe the rotation of the planes on the sphere with the phase value in the Rotation tab. I am able to insert an initial keyframe, but it is impossible to change the value afterwards, even with the graph editor.
This report can be considered as a duplicate of T47080 . To simplify, none of settings related to initial state (Emission, Initial Velocity, Initial Rotation) can be animated.
There is a warning only for some settings and first keyframe insertion is not prohibited for all of them.
So, clarification in User Interface is still a TODO that should be solved during 2.8 development.
Currently, if you want to animate particles rotation, you have to animate rotation of dupli-objects or force fields instead of particles ones.
Or you have to use Emitter particles with a Newtonian physics type and use dynamic angular velocity.
ronan ducluzeau (zeauro) claimed this task.
