blank screen?
Closed, InvalidPublic
Windows 10 enterprise, X299 7900x, GeForce 1080TI card. Nvidia drivers updated to latest version TODAY.
Blender 2.79 (sub 0)
build date: Mon 09/11/2017
build time: 07:44 AM
build commit date: 2017-09-11
build commit time: 10:43
build hash: 5bd8ac9
build platform: Windows
New to blender. Downloaded version above, upon starting a transparent window appears with nothing in it, i.e., can see the border of the window, but the contents are that of the windows and desktop that were open at the time Blender was started. No menus or screens relevant to the blender program are visible. Updated Nvidia drivers to no avail. --factory-startup option does not help. Thanks
Vuk Gardašević (lijenstina) triaged this task as Incomplete priority.Nov 30 2017, 9:32 AM
From the description it is possible to be a GPU driver issue.
  • Try to run Blender through Software OpenGL, this will be much slower however, if everything works then it means that the bug is specific for your GPU/Driver and you should report the bug to your GPU vendor instead.
  • Download this dll and copying it so its located in the same directory as blender.exe and run Blender normally.
If Blender starts it is related to a GPU driver.
Marking as Incomplete until the requested information/data is provided.
Thanks. With software OpenGL it works.
Any thoughts for fixing the issue with the GPU driver? I just reinstalled the driver and it has not helped. I am on the latest version of the driver for the 1080TI per NVIDIA's website. Other OpenGL applications seem to work fine.
Thanks
I'm not sure about what we can do with the driver itself apart from reporting it to Nvidia if the issue can be recreated by developers. There are some issues with Titan X Pascal cards too. T53179 (viewport / UI glitches).
Fable Fox (fablefox) closed this task as Invalid.Dec 16 2017, 4:50 AM
Fable Fox (fablefox) claimed this task.
Closing this since software OpenGL proves that it was a driver issue, and the fact that it has no activity for the past 7 days.
