Track To constraint makes object disappear
Win 7 64bit
Broken: 2.79
Worked: 2.78 (fb1cd76)
Track To constraint on straight Z axis is inconsistent
Load default scene, translate Cube to (0, 0, -1.7)
Clear Camera transforms (ALT G, ALT R)
Select Camera and then SHIFT click select Cube
Track (CTRL T) Camera to Cube and select Track To -> Camera shrinks to nothing
File is ready to press CTRL T
Not seeing that here on macOS on either 2.79 release or latest buildbot.
Sergey Sharybin (sergey) triaged this task as Needs Information from User priority.
I can not reproduce the issue on neither Linux nor Windows 10, both 64 bit.
  1. Can the issue be reproduced after doing File -> Load Factory settings?
  2. Can the issue be reproduced with latest builds from buidler.blender.org?
If so, please provide .blend file right before you click "Ctrl-T".
Updated first post with file and video.
Latest build and "load factory settings" doesn't help, but I've tried 2.78 (fb1cd76) and it works without problems
Serge Lyatin (SergeL) updated the task description. (Show Details)
Joshua Leung (aligorith) raised the priority of this task from Needs Information from User to Confirmed, Medium.
Can confirm on the provided file. This only seems to affect the "TrackTo" constraint, and not the "Damped Track" or "Locked Track"
only happens when camera is exactly above the Cube on the Z-Axis (constraint works normally when you start moving the cube away from that axis)
Not sure why the constraint actually affects scaling at all... will have a look...
Thanks for tracking down the commit. This is quite an edge case - while the vector is normalized it's so close to zero to begin with, a second call is needed to make it really normalized (which fixes the bug).
Since this code was working beforehand, revert my change with comment on why.
