Subsurf don't work
Closed, InvalidPublic
Windows 10 Home, 3xGTX 980Ti
Broken: (example: 2.79 5bd8ac9, 2017-09-11 10:49)
1 - I worked in file, when created in Blender 2.78 - of course I worked in Blender 2.79
Dos't work Modifier - Subsurf,
When I created new scene - Subsurf works correctly
In This file I have only 2 object - UV Sphere, and this file weighs 475 MB
Of course, I had different scene and objects - but I all removed and I do "Orphan Data" - "Purge All"
https://www.dropbox.com/s/0hmxum8s9d8bi05/bugSubsurf.blend?dl=0
Rafal Szostek (elephantstudio) renamed this task from 2 Bugs to 2 Bugs - Subsurf and material Emission .Dec 6 2017, 11:36 AM
Please separate these bugs. Only one bug per report :)
Rafal Szostek (elephantstudio) renamed this task from 2 Bugs - Subsurf and material Emission to Subsurf don't work.Dec 7 2017, 3:41 PM
Rafal Szostek (elephantstudio) updated the task description. (Show Details)
Hello Rafal,
Probably a language barrier here. Are you saying you create a subsurfed object in 2.78, and when you open it in 2.79 it is not working?
If so, I did just that. Placed a UV sphere in 2.78, hit control 2 to add subsurf level 2, and then save that file. I opened it in 2.79 and it is working the same, in other words it is subsurfed.
If you can explain the issue you are experiencing a little more that would be good.
thanks
Sorry, maybe somebody else wants to, but I'm not going to download half a Gig file.
To make subsurf work, go to Scene properties and disable Simplify or change the subdivision settings to allow levels higher than 0.
