Circle Select don't respect "Limit to visible" toggle.
macOS Sierra AMD Radeon 6770M 512Mb
Broken: 237df2f860
Worked: blender 5db8ac9
In Mesh Edit mode:
Circle select Tool don't respect "Limit Selection to visible" toggle.
Tool always select polygons only by clicking on center and may to select invisible polygons from other side.
If switch to vertex/edge selection and select some elements, circle select begins to work normally in the face mode.
Related Objects
Joel Godin (FloridaJo) triaged this task as Confirmed, Medium priority.Dec 12 2017, 10:44 PM
I don't know if I understood the problem correctly. (I tested in several possible ways and found no abnormality)
Could you download one of the latest builds to confirm that the problem still occurs?
https://builder.blender.org/download/?hc_location=ufi
Joel Godin (FloridaJo) raised the priority of this task from Confirmed, Medium to Needs Triage by Developer.
ah, must have been fixed recently. 12-13 build does not do that here.
