Bump Node Outputting Pure Black #53518
Reference: blender/blender#53518
Windows 7
EVGA GeForce GTX 770 Classified 4GB GPU
2x Intel Xeon E5-2670 8-cre 2.6 Ghz
8 GB ADATA RAM @1833Mhz
Broken: Blender 2.79a (Hash:
5bd8ac9
) and Blender 2.79.1 (Hash:2ae6a93
)Worked: N/A
In short, I don't know for sure if it's a bug, or an intended limitation of Cycles nodes. I have over like 450 nodes, and the bump no longer works when certain ones are plugged into it, and instead acts as if it's a black emission node, as does the Principled BSDF if the Bump node is connected.
It's worth noting I had a friend test on his rig, and his own blender version, and it didn't work for him either.
Just download the .blend, and it's already done for you. To "fix" it, simply delete the Reroute marked "REMOVE ME" or the Reroutes labelled "OR REMOVE US". steel_shader_002.blend
Added subscriber: @JoeyBennett
Added subscriber: @FloridaJo
Change this node from Multiply to Mix.
See if that fixes it for you. Everything else besides Mix, makes it black.
In the meantime, I'll see if I can recreate with a simpler set up.
@JoeyBennett Joey, I started reducing this bug, but it's a massive node layout, can you do that? Delete things until you get to the minimum node setup where that still is outputting black?
Added subscriber: @GregZaal
For me this prints an error in the console:
Cycles: out of SVM stack space, shader "Steel" too big.
Added subscriber: @Sergey
Thanks for the report, but it is a known limitation. Your shader requires too many stack variables for the shader machine. While re-route nodes doesn't necessarily require extra stack space, having them in shader graph changes the way how graph is being travesred.
There is some ongoing development to optimize stack usage, but is not all finished yet. See D1676.
