Generated Texture Coordinate works not as expected when used with curve and boolean modifier #53622
2 Participants
Reference: blender/blender#53622
Windows 10
Geforce GTX980
stable release: 2.79
5bd8ac9
experimental: 2.79
5e28b71
Generated texture coordinate changes when using boolean modifier
I used the Curve modifier on meshes for building Brickwalls.
I added Textures with the Bricktexture with the generated texture coordinate in Cycles.
This worked until I used the boolean modifier to cut holes for windows and doors.
In the File you can see that the texturecoordinate changes when the boolean mesh touches the wall.
Even if it's only partly.
I'm not sure if this is an error, but I don't know how I could do this otherwise.
I tried to apply the modifiers but then the texturecoordinate also looses the shape of the curve.
It's otherwise possible to use uv coordinates instead but then the texturespace is limited by the size of the mesh.
Curve boolean generated Texture.blend
Added subscriber: @MarcZbinden
Added subscriber: @lichtwerk
This is not only a problem of the curve or boolean modifiers specifically.
(It could also be a bend with a decimate afterwards e.g)
So afaik this is due to a constructive/generating modifier after a deforming modifier
when you only have a deform modifier it will still use to coordinates from the original space (thats why the bricks 'stick' nicely)
once a constructive modifier comes into play afterwards we have a new boundingbox/space and thats the basis now.
(Having a hard time finding the right words atm. but to sum it up: I think this is expected behaviour and I wouldnt consider this a bug)
However you can still kind of make your case possible [a lot less convenient though] by moving the boolean above the curve modifier [its less intuitive to place the boolean object right then...]
This way all geometry modification (array/boolean) takes place in a lined up space, and the deforming comes last
T53622_workaround.blend
