See T54255 for 2.79b
This task is to track status of 2.79a release.
UP TO rB71c93624e239
Applied
rBadd580beee | 2018/01/06 | Aaron Carlisle | Fix T47212: Luminance Key not working with HDR and out-of-gamut ranges |
rB94a3ee56c7 | 2017/12/20 | Antonio Vazquez | Fix MSVSC2017 error |
rB1effab7809 | 2017/10/26 | Arto Kitula | Fix T52984. Trackpad rotation to natural direction |
rBc57636f060 | 2017/09/14 | Bastien Montagne | Fix failure in our UI code that could allow search button without search callbacks, leading to crash |
rB3c1c3b64c5 | 2017/09/14 | Bastien Montagne | Fix T52729: Decimals not showing over 100m or 100 feet |
rB785e96a11d | 2017/09/18 | Bastien Montagne | Fix (irc-reported by @Sergey Sharybin (sergey)) invalid precision value in a float RNA property |
rBbb4a12914f | 2017/09/18 | Bastien Montagne | Add some security checks against future bad float UIprecision values |
rB9591b5f618 | 2017/09/19 | Bastien Montagne | Fix T52816: regression can't open file in 2.79 (crash) |
rB98d797b67c | 2017/09/20 | Bastien Montagne | Fix missing ID remapping in Action editor callback |
rB1d8aebaa096f | 2017/09/25 | Bastien Montagne | Add an 'atomic cas' wrapper for pointers. |
rB63482a5f2e | 2017/10/05 | Bastien Montagne | Fix T53002: Batch-Generate Previews generate empty or none image for large objects |
rB9ea2a7c02d | 2017/10/08 | Bastien Montagne | Fix potential string buffer overruns |
rB383df45af9 | 2017/10/15 | Bastien Montagne | Fix bad 'poll' prop callback API doc |
rBca006deafe | 2017/10/30 | Bastien Montagne | Fix T53191: Python API Reference link wrong in splash screen |
rBb28da9dbf8 | 2017/11/06 | Bastien Montagne | Fix T53250: Crash when linking/appending a scene to a blend when another linked scene in this blend is currently open/active |
rB556b13f03e | 2017/11/14 | Bastien Montagne | Fix T53309: Remove default 'Clear loc/rot/scale delta transform' shortcuts |
rB784614655f | 2017/11/19 | Bastien Montagne | Fix T53343: Custom Normal Data Transfer Crashes when some vertexes have no faces |
rB9f1048481c | 2017/11/29 | Bastien Montagne | Fix T53420: Vertex Groups: The "-" button gets a hidden function |
rB1802d14394 | 2017/12/04 | Bastien Montagne | Fix T53463: Rotation numerical input shows instable behaviour |
rBd130c66db4 | 2017/12/22 | Bastien Montagne | Fix scalability issue in threaded code of Mesh normals computation |
rB17f1ce4d4f | 2017/12/28 | Bastien Montagne | Fix T53630: Effect strips not displaying Input data. Fix T52977: Parent bone name disappeared in the UI in pose mode. |
rBe84966ac42 | 2018/01/02 | Bastien Montagne | nstall_deps: llvm downloads new website location |
rB96e507d989 | 2018/01/08 | Bastien Montagne | Fix T53509: Datablock ID Properties attached to bpy.types.Material are not loaded |
rB850f73638c | 2018/01/08 | Bastien Montagne | install_deps: Fix OCIO always re-cloning its whole git repository |
rBc528b9b77773 | 2018/01/26 | Bastien Montagne | Fix T53003: IMB: Invalid framerate handling due to short integer overflow. |
rB567afcca2021 | 2018/01/26 | Bastien Montagne | Related to T53003: tweak scene fps range. |
rB47a3bbcc3418 | 2018/01/26 | Bastien Montagne | IMB: Add asserts that returned fps and fps base are strictly positives. |
rBf309becf2d56 | 2018/01/31 | Bastien Montagne | Fix possible concurrency issue in mesh normals computation. |
rB293723fc7f6 | 2018/02/01 | Bastien Montagne | Fix T53975: Vertex colors transfer crash |
rBea9099473a5 | 2018/02/09 | Bastien Montagne | Fix (unreported) crash when duplicating a FileBrowser window in preview draw mode. |
rBd454a44e96 | 2017/09/12 | Brecht Van Lommel | Fix Cycles bug in RR termination, probability should never be > 1.0 |
rBd0d9360a66 | 2017/09/18 | Brecht Van Lommel | Fix T52800: fix UI flickering with Mesa on Linux |
rB6bf3dfbcdb | 2017/09/18 | Brecht Van Lommel | Fix T52801: reload scripts causes Cycles viewport render crash |
rB64f8cc3e7d | 2017/10/05 | Brecht Van Lommel | Fix T52998: disabled menu entries responding to key shortcuts |
rBc82efd3276 | 2017/10/06 | Brecht Van Lommel | Fix T52514: don't clear filename when dropping directory path in file browser |
rBc040dedc12 | 2017/10/07 | Brecht Van Lommel | Fix incorrect MIS with principled BSDF and specular roughness 0. |
rBc74c72101e | 2017/10/20 | Brecht Van Lommel | Fix compositor node links getting lost on file load for custom render passes |
rB0e3fd70d7a | 2017/11/07 | Brecht Van Lommel | Fix T53129: Cycles missing update when changing image auto refresh |
rB3dec1de275 | 2017/11/07 | Brecht Van Lommel | Fix incorrect color management when saving JPG previews for EXR |
rBebcb880375 | 2017/11/12 | Brecht Van Lommel | Fix T53273: render bake settings properties not showing correct Python path |
rB56da112ae0 | 2017/11/23 | Brecht Van Lommel | Fix T53360: crash with GLSL bump mapping and missing group output node |
rB5e13097dc3 | 2017/11/23 | Brecht Van Lommel | Fix T53145: bevel tool fails when used a second time |
rB2bf3825711 | 2017/11/27 | Brecht Van Lommel | Fix T53145: bevel tool does not start with amount at zero |
rB07dbff7dc1d | Brecht Van Lommel | Fix T53217: GLSL principled BSDF black with zero clearcoat roughness.] | |
rB18a353dd242 | Brecht Van Lommel | Fix T52368: Cycles OSL trace() failing on Windows 32 bit.] | |
rBd089875c4c7 | Brecht Van Lommel | Fix build with OSL 1.9.x, automatically aligns to 16 bytes now.] | |
rBe50ed90e4df | Brecht Van Lommel | Fix T53348: Cycles difference between gradient texture on CPU and GPU.] | |
rBf55735e5336 | Brecht Van Lommel | CMake: support CUDA 9 toolkit, and automatically disable sm_2x binaries.] | |
rBd85a0a722e5 | Brecht Van Lommel | Fix part of T53038: principled BSDF clearcoat weight has no effect with 0 roughness.] | |
rB05b08a3 | Brecht Van Lommel | Fix T53092: errors reading EXR files with different data/display window] | |
rBdebd9f6 | Brecht Van Lommel | Fix T53171: lamp specials strength tweak fails with renamed emission nodes.] | |
rB948515c | Brecht Van Lommel | Fix T53600: Cycles shader mixing issue with principled BSDF and zero weights. | |
rB2ca933f | Brecht Van Lommel | Fix T53755: Cycles OpenCL lamp shaders have incorrect normal. | |
rB30a0459 | Brecht Van Lommel | Fix T53692: OpenCL multi GPU rendering not using all GPUs. | |
rB0dfcf7b0d2fe | Brecht Van Lommel | Fix T52924: buffer overflows in TIFF, PNG, IRIS, DPX, HDR and AVI loading. | |
rB3ff9aab8f2c8 | Brecht Van Lommel | Fix T52924: buffer overflow vulernability in thumbnail file reading. | |
rBe04d7c4 | Brecht Van Lommel | Fix T52924: buffer overflow vulnerabilities in mesh code. | |
rBe6df028 | Brecht Van Lommel | Fix T52924: buffer overflow vulnerability in curve, font, particles code. | |
rBe53447c | Brecht Van Lommel | Fix old files with changed node socket type not loading correctly. | |
rBbbc562f | Brecht Van Lommel | Fix T53593: sculpt brush rake spacing bug after recent bugfix. | |
rB0e37c98 | Brecht Van Lommel | Fix part of T53080: all material previews re-rendering after undo. | |
rBb37dff9 | Brecht Van Lommel | Fix part of T53080: don't use current scene world for icon previews. | |
rBd827186c17 | 2017/09/14 | Campbell Barton | Fix T52723: Reset UV layers failed |
rB909da553e3 | 2017/09/14 | Campbell Barton | Fix bpy.utils.resource_path('SYSTEM') output |
rB2aa2bec43a | 2017/09/14 | Campbell Barton | Fix T52442: bl_app_templates_system not working |
rB8c21003248 | 2017/09/14 | Campbell Barton | Fix T52748: Select shortest face path fails |
rBfc7ac0bc49 | 2017/09/14 | Campbell Barton | Correct error in last commit |
rB378b74f025 | 2017/09/15 | Campbell Barton | Docs: only show versions in changelog side-bar |
rB7c8e87fc52 | 2017/09/15 | Campbell Barton | Fix T52384: Bridge pair result depends on other loops |
rBd09c429e30 | 2017/09/16 | Campbell Barton | Fix writing Iris images w/ invalid header |
rBa850d74312 | 2017/09/16 | Campbell Barton | Fix T51074: Boolean modifier inverts operation |
rB9134529b9e | 2017/09/17 | Campbell Barton | UI: avoid int cast before clamping number input |
rBadb647fb92 | 2017/09/20 | Campbell Barton | UI: fullstop at end of tooltips |
rB806bc55a34 | 2017/09/21 | Campbell Barton | Fix T52860: 3D Text crashes w/ Ctrl Backspace |
rB4e15eddb52 | 2017/09/25 | Campbell Barton | Fix T52890: Crash unlinking sequencer sound |
rB296757804c | 2017/10/04 | Campbell Barton | Fix error copying smoke modifier uv layer |
rBffb190244c | 2017/10/05 | Campbell Barton | Fix setting the operator name in Py operator API |
rB327bb6e543 | 2017/10/06 | Campbell Barton | Fix ruler access from search pop-up |
rB7d3723a54d | 2017/10/17 | Campbell Barton | Fix T52959: Local view looses clip range on exit |
rB2103194f79 | 2017/10/25 | Campbell Barton | Fix T53004: XWayland ignores cursor-warp calls |
rB282af08fe2 | 2017/10/27 | Campbell Barton | Fix T53131: Incorrect vert-edge angle calculation |
rB5b3c15e336 | 2017/11/12 | Campbell Barton | Fix T53294: bpy.ops.image.open crash |
rB8f56cebe72 | 2017/11/18 | Campbell Barton | Fix BGE sound actuator property access |
rBed3b7a5cd4 | 2017/11/20 | Campbell Barton | Fix T53342: Outliner 'select hierarchy' broken |
rBdf7b9fa2ee | 2017/11/30 | Campbell Barton | Fix T53410: 3D Text always recalculated |
rBe6404274a1 | 2017/12/06 | Campbell Barton | Fix T53441: Inset doesn't start at zero |
rB54f7bb4582 | 2017/12/11 | Campbell Barton | Fix for inset when accessed from spacebar search |
rBbe54868ec3 | 2017/12/13 | Campbell Barton | Fix T53529: Rip crashes w/ wire edge |
rB99b7dc60be | 2017/12/14 | Campbell Barton | Fix missing update for particles w/ fluids |
rB1f95347882 | 2017/12/14 | Campbell Barton | Fix T53322: Collada export crash w/ shape keys |
rB076616898b | 2017/12/18 | Campbell Barton | Fix T53577: Rake sculpt/paint wrong on first step |
rBcbc7aa80d4 | 2018/01/03 | Campbell Barton | Fix T53678: Smart Project UV margin ignores units |
rB0becc8a7dd | 2018/01/04 | Campbell Barton | Fix T52953: Crash removing material |
rBa7b4f98e73 | 2018/01/08 | Campbell Barton | Fix T53713: User remap failed w/ texface images |
rB31f67f766979 | Campbell Barton | Fix writing Iris images w/ invalid header | |
rB6a8322261896 | Campbell Barton | Fix SGI format reader vulnerability (CVE-2017-2901) | |
rB42a5624 | Campbell Barton | Fix memory leak in recent curve refactor | |
rB7c64e33b01 | Campbell Barton | makesdna/makesrna: silence output by default] | |
rBd19d094ca9 | Campbell Barton | Fix incorrect allocation size] | |
rB974053f7e | Campbell Barton | Fix brush reset (missing notifier) | |
rB775c773cf | Campbell Barton | Fix sculpt secondary color missing some brushes | |
rBb29e37ed8 | Campbell Barton | Docs: add note for bmesh face_split_edgenet | |
rB8fb2e4619 | Campbell Barton | Edit Mesh: click extrude, ensure inverse matrix | |
rB3859f5ec2 | Campbell Barton | Docs: correct descriptions | |
rBc93cfcbb6 | Campbell Barton | Fix edge-split bmesh operator giving empty result | |
rB8661ab12a | Campbell Barton | Fix BMesh PyAPI internal flag clearing logic | |
rB1d409defb | Campbell Barton | Docs: clarify return value for BVH API | |
rB69b516590 | Campbell Barton | WM: minor correction to user-pref writing | |
rB855799ecc | Campbell Barton | Fix T53430: Cut at the strip end fails w/ endstill | |
rB4a734325f | Campbell Barton | bl_app_override: support empty UI layout items | |
rB7a58ff928 | Campbell Barton | Math Lib: signed versions of quaternion angle | |
rBe418c858 | Campbell Barton | 3D View: use shortest angle between quaternions | |
These commits relate to T52291 however other changes were made relating to it which should be included to keep output compatible, also applying changes to avoid merge conflicts. | |||
rB9c7b89241 | Campbell Barton | BLI_utildefines: sync w/ 2.8 | |
rBc4fc9c4a8 | Campbell Barton | Math Lib: clamped rounding utility functions | |
rB892d304de | Campbell Barton | Fix T52291: Boolean fails w/ co-linear edged ngons | |
rBfdb8e1793 | Campbell Barton | Fix error in recent boolean changes w/ quad split | |
rBc59408748 | Campbell Barton | Polyfill Beautify: option to rotate out of degenerate state | |
rBd120780fe | Campbell Barton | BMesh: use less involved check for edge rotation | |
rB9a2f7dd77 | Campbell Barton | Correct recent error in boolean quad split check | |
rB36f5972ed | Campbell Barton | Avoid bias when calculating quad split direction | |
rB215651af1 | Campbell Barton | Boolean Modifier: add debug options | |
rB6178cf835 | Campbell Barton | Cleanup: use stubs for eigen gtest | |
rBb1f2b6988 | Campbell Barton | Missing from last commit | |
rBe00bb4d22 | Campbell Barton | BLI_polyfill2d_test: Try flipped x/y axis | |
rBc4235356c | Campbell Barton | BLI_polyfill2d_test: add test for T52834 | |
rBf680e42a4 | Campbell Barton | Correct test ifdef in polyfill | |
rB959a58da9 | Campbell Barton | Cleanup: redundant casts | |
rBa2d246c5c | Campbell Barton | BLI_polyfill2d_test: script to generate test data | |
rBa8f11f542 | Campbell Barton | Fix T52871: BLI_polyfill_beautify_quad_rotate_calc_ex was mistakenly considering the state as degenerated | |
rB293dc4e08 | Campbell Barton | Revert "Fix T52871: BLI_polyfill_beautify_quad_rotate_calc_ex was mistakenly considering the state as degenerated" | |
rBe40e29cd3 | Campbell Barton | Fix T52871: beauty fill error | |
rBaba2f8ea6 | Campbell Barton | Beauty fill was skipping small faces | |
rB6dfe4cbc6 | Campbell Barton | Polyfill Beautify: half-edge optimization | |
rBaf067f230 | Campbell Barton | Correct gtest error in recent beautify change | |
rBb84e3dc7f | Campbell Barton | GTest: initial BLI_heap test | |
rB4af1af70a | Campbell Barton | BLI_hash: add BLI_heap_reinsert | |
rB336885beb | Campbell Barton | Use BLI_heap_reinsert for decimate and beautify | |
rB342573292 | Campbell Barton | BLI_heap: minor changes to the API | |
These commits are to fix application templates, bug T53274 & T53637: | |||
rB0398ee10a1 | Campbell Barton | WM: don't load preferences on 'File -> New' | |
rBb500f42700 | Campbell Barton | WM: load UI for new file, even when pref disabled | |
rBd749320e3b | Campbell Barton | BLI_utildefines: Support SWAP macro with two args | |
rB326efb4319 | Campbell Barton | Fix T53274: Saving template prefs overwrites default prefs | |
rB3bec70ca60 | Campbell Barton | Use custom SWAP macro for swapping userdef data | |
rB434ed96dd2 | Campbell Barton | Revert "BLI_utildefines: Support SWAP macro with two args" | |
rB9b65560934 | Campbell Barton | Fix T53637: Keymap from app-template ignored | |
These commits are to resolve conflicts for T53143 | |||
rB990515a5a7 | Campbell Barton | Math Lib: add divide_floor_i | |
rBa0e7dbc66d | Campbell Barton | BMesh: move bridge tools stepping logic into macro | |
rB7b95243240 | Campbell Barton | BLI_utildefines_iter: Use for iteration helpers | |
rB136f33b09f | Campbell Barton | Fix T53143: Knife Crash after Grid Fill | |
rB6eb89027c3 | Campbell Barton | Fix T53696: Compositor HSV limits changed | |
rB6d8f63a834 | 2017/10/16 | Campbell Barton | Fix T53054: Parentless bone + IK crashes |
rB4b3e6cb728 | 2017/10/08 | Campbell Barton | Cleanup: --help text |
rB457dc8d12c | Campbell Barton | Fix T53586: Surfaces collapse when joined | |
rBa7b4f98e73 | Campbell Barton | Fix T53713: User remap failed w/ texface images | |
rB98d89cef6b9 | Campbell Barton | Fix background_job template | |
rB0edda8e4ce4 | Campbell Barton | Fix T53311: transform edge/normal orientation | |
rBa33a5880f7a | Campbell Barton | Fix bmesh.utils.face_join arg parsing | |
These Commits resolve CVE-2017-2901 | |||
rBa72e609204 | Campbell Barton | Cleanup: SGI format, use uint/short/char types | |
rBb884188f8a | Campbell Barton | Cleanup: SGI format, avoid overflow | |
rB829916f4e5 | Campbell Barton | Fix SGI foramt reader CVE-2017-2901 | |
rBd7204aed95 | Campbell Barton | Cleanup: SGI format, remove unused struct members | |
rB8d3efb2b90 | Campbell Barton | Fix T53772: Presets don't support colons | |
rB2b9fb723ed | Campbell Barton | Fix T53832: Particle weight paint crash | |
rB368414efac | Campbell Barton | Fix T53823: Particle weight brush crash | |
rB56fc812d1e | Campbell Barton | Fix manual lookups (data is now lowercase) | |
rBfb4582134a | Campbell Barton | Fix T53850: Lock to Cursor breaks 3D manipulators | |
rBd7c7ce2a7b | Campbell Barton | BLI_kdtree: utility function to remove doubles | |
rB567b4fa794 | Campbell Barton | Fix T52634: EditMesh Remove doubles could hang | |
rB65d40b3eeb | Campbell Barton | Docs: invoke_search_popup uses bl_property | |
rB22afe88882 | Campbell Barton | Fix navmesh creation w/ multiple objects | |
rBb0af44fa4d | Campbell Barton | Fix T50630: Fluid fails on win32 w/ unicode paths | |
rBceb645bc56 | Campbell Barton | Fix T53986: Crash saving during sculpt stroke | |
rBf911fb0744 | Campbell Barton | Minor change to last commit | |
rB8a6b83d27e | Campbell Barton | Fix T53958: Sequencer zoom 1:1 fails | |
rB56fa48969e | Campbell Barton | Fix T54072: Crash splitting edges | |
rB6981861fcf | Campbell Barton | Cleanup: Python context access | |
rB58ba89b5be | Campbell Barton | Fix T54075: Align Objects fails w/ empty mesh | |
rB6535f668b4 | Campbell Barton | Address T54048: Skip non image/movie w/ proxy dir storage | |
rB92b342d30d | 2017/11/09 | Dalai Felinto | Fix logic for pinning textures users from context |
rBa6c69ca57f | 2017/12/29 | Dalai Felinto | Fix T53513: Particle size showing in multiple places |
rB95d83b9b23 | 2018/01/04 | Dalai Felinto | Fix leak when rendering OpenGL animations |
rB2dfd795bd2 | 2017/12/06 | Daniel Silva | Proposed fix for T53263 -- Blender crashes when rendering with Stabilizer 2D node without movie selected |
rB26f98446b1 | 2017/09/21 | Gaia Clary | fix T52831 removed enforcement of matrix decomposition when animations are exported |
rBe59cf13b8c | 2018/01/01 | Gaia Clary | fix T53230: avoid Nullpointer problems in Collada Exporter |
rB96ce50449c | 2017/09/19 | Howard Trickey | Fix T52733 Percent mode for Bevel sometimes had nans |
rB87607254d6 | 2018/01/07 | Ines Almeida | (Nodes) Display image name if any in the Image and Texture Image node title |
rB5ec8a9ac27 | 2017/11/29 | José Luis Oliveira Cunha | Fix T53116: default texture coordinates for volume materials are blank |
rBd2202117fe | 2017/09/12 | Joshua Leung | T50354: Action length calculation added unnecessary padding if some F-Curves only contained a single key (on the last real frame of the action) |
rBfde45132de | 2017/09/21 | Joshua Leung | Fix T52861: Keymap editor filter doesn't show shortcuts using "+" |
rBb0ccf2322b | 2017/09/26 | Joshua Leung | Fix: When transforming GP strokes in "Local" mode, the strokes would get obscured by the transform constraint lines |
rB1e07f366e6 | 2017/10/28 | Joshua Leung | Fix T53185: After rendering an animation (Ctrl-F12), pressing F12 no longer renders single frames only |
rB6f578740ef | 2017/11/19 | Joshua Leung | Fix T53300: Bone Extrude via Ctrl + Click is not done from active bone tail |
rBd2b03d2364 | 2017/11/19 | Joshua Leung | Fix: Undo pushes were missing for Add/Remove Driver Variable buttons, and Remove Driver button |
rBbf1dc39679 | 2017/12/21 | Lukas Stockner | Fix T53567: Negative pixel values causing artifacts with denoising |
rBb1a036861d | 2017/12/20 | Martin Felke (scorpion81) | Fix T53572: Alembic imports UV maps incorrectly |
rB5aa08eb3cc7 | Mathieu Menuet | Fix T53017: Cycles not detecting AMD GPU when there is an NVidia GPU too. | |
rB08b063a19f | 2017/12/29 | Philipp Oeser | Fix T53639: text sequence strips no stamped into render |
rBc6abf41f71 | 2018/01/06 | Philipp Oeser | Fix T53650: remove hard limits on force field size and max distance |
rB433c74d9f7 | 2017/12/19 | Ray Molenkamp | bpy_extras: add missing colorband keymap to keyconfig_utils.py |
rB7e928c3bbc5a | Ray Molenkamp | Fix: msvc build error with bli_fileops.h | |
rB00067afa10 | 2017/12/07 | Sebastian Koenig | Fix T53419: Masking "Add" menu is not present in Image editor, but shortcut is |
rBc8a989d644 | 2018/01/08 | Sebastian Koenig | No groping in Blender's Tracker! |
rB4aee701f00 | 2017/09/12 | Sergey Sharybin | Fix T52679: Hole in bake normal |
rBfadc079740 | 2017/09/12 | Sergey Sharybin | Fix T52573: Cycles baking artifacts |
rB76e7c039ec | 2017/09/13 | Sergey Sharybin | Fix T52140: Align objects centers using origin for text |
rB6f633dec5d | 2017/09/13 | Sergey Sharybin | Fix T52299: X resolution of 4 causes nodes to collapse |
rB8140b51aa4 | 2017/09/14 | Sergey Sharybin | Fix T52739: Crash loading corrupted video files |
rB7aafa32c09 | 2017/09/14 | Sergey Sharybin | Fix T51416: Blender Crashes while moving Sliders |
rB7177e0ac3e | 2017/09/19 | Sergey Sharybin | Fix T52811: At any framerate selected, video exported with 1000fps |
rBf320d0e0a8 | 2017/09/22 | Sergey Sharybin | Fix T52840: New Depsgraph - Mask editor not working correctly |
rB840cce840e | 2017/09/23 | Sergey Sharybin | Tracking: Fix crash when tracking failed |
rBd430c462a3 | 2017/09/23 | Sergey Sharybin | Fix T52851: Per-frame traking is broken when sequence doesn't start at frame 1 |
rB92aff05a7c | 2017/09/23 | Sergey Sharybin | Tracking: Cleanup, reuse existing variable |
rB874062b6ab | 2017/09/23 | Sergey Sharybin | Tracking: Followup to previous fix, need to remap frame number for sequence tracking |
rB75e8e3779b | 2017/09/28 | Sergey Sharybin | Curves: Fix wrong bitset being checked against CYCLIC bit flag |
rB3801f76b7b | 2017/09/28 | Sergey Sharybin | Fix T52932: Driver with target of custom property from scene fails to update |
rB5ea729845d | 2017/10/11 | Sergey Sharybin | Fix T53048: OSL Volume is broken in Blender 2.79 |
rBf1c7243376 | 2017/10/31 | Sergey Sharybin | Tracking: Create mesh from selected tracks only |
rB6785a2bd66 | 2017/11/21 | Sergey Sharybin | Fix T53371: Keying Node fails with values above 1 |
rBc34f3c777f | 2017/12/19 | Sergey Sharybin | Fix T53559: Auto texture space for text and font is wrong in Cycles |
rBf7163a7d0a | 2017/09/14 | Sergey Sharybin | Fix T52741: Follow track with depth object crashes Blender with new depsgraph |
rBb31faac17e | 2017/09/19 | Sergey Sharybin | Depsgraph: Fix wrong flag being assigned |
rB4fde0910d52 | Sergey Sharybin | Compositor: Cleanup, reduce indentation level in render layer node | |
rB17a117c7a00 | Sergey Sharybin | Compositor: Cleanup, de-duplicate some code | |
rBf472aea9220 | Sergey Sharybin | Compositor: Cleanup, get rid of nested ternary operators | |
rB04800ed4343 | Sergey Sharybin | Fix T52113: Compositor doesnt mix unrendered render layers well | |
rB3573f49bfdc | Sergey Sharybin | Masks: Split layer evaluation into separate function | |
rB09c6c6c486f | Sergey Sharybin | Fix T52749: New Depsgraph - Render View Mask is not initialized correctly | |
rB8b3ad25862e | Sergey Sharybin | Transform: Enable recursion dependency check for new depsgraph | |
rBc622533fa01 | Sergey Sharybin | Fix T52432: Blender crashes while using Ghost (new depsgraph) | |
rB4808c488c51 | Sergey Sharybin | CMake: Add extra requests dependencies | |
rB0d4e519b748 | Sergey Sharybin | OpenVDB: Fix compilation error against OpenVDB 4 | |
rB675cef0a165 | Sergey Sharybin | Fix T52835: When driven IK influence change, ik animation have 1 frame delay | |
rB83ce02879f7 | Sergey Sharybin | Cycles: Fix possible race condition when generating Beckmann table | |
rBb65fecd9a09 | Sergey Sharybin | GPU: Fix memory corruption in GPU_debug on GTX1080 | |
rBbe5123a0a9c | Sergey Sharybin | Space clip: Make it more clear that filter track does not use any settings from tool shelf | |
rB2868dcbe2bc | Sergey Sharybin | Fix compilation error with clang-5 | |
rB4782000fd5 | Sergey Sharybin | Cycles: Fix possible race condition when initializing devices list] | |
rB01a0649354 | Sergey Sharybin | Cycles: Fix wrong shading when some mesh triangle has non-finite coordinate] | |
rB8a03e4d409 | Sergey Sharybin | Depsgraph: Fix relations for metaballs] | |
rB2ac33b47dc | Sergey Sharybin | Fix T53547: Metaballs as dupli objects are not updated with the new Depsgraph | |
rBc45afcfa81e | Sergey Sharybin | Depsgraph: Don't make non-dynamic hair dependent on time | |
rB9c0a38ee338 | Sergey Sharybin | Depsgraph: Add missing checks from previous commit | |
rB2c64615438 | 2017/12/13 | Sergey Sharybin | Fix T53552: Unneeded particle cache reset on frame change |
rB467d92b8f1 | 2017/09/12 | Sergey Sharybin | Cycles: Tweaks to avoid compilation error of megakernel |
rBa22590a62c | 2017/09/14 | Sergey Sharybin | Fix T52537: Dyntopo "detail flood fill" doesn't work in some cases |
rBc75bd25cd8 | 2017/09/14 | Sergey Sharybin | Fix T52732: Particle system volume grid particles out of volume |
rB95a8e73d40 | 2017/09/15 | Sergey Sharybin | Fix copy-paste error in recent particles fix |
rB1a9217e222 | 2017/09/15 | Sergey Sharybin | Fix T52763: Boolean problem with vertex group |
rB1a4442b3db | 2017/09/19 | Sergey Sharybin | Fix T52823: New Depsgraph - Shrinkwrap crashes blender |
rB9ddee885ae | 2017/09/28 | Sergey Sharybin | Fix T52086: Graph editor "normalize" drag errors for integers |
rB04704297d2 | 2017/10/02 | Sergey Sharybin | Fix T52920: Saving Tiff Files type Blender crashes |
rB64c1a48c50 | 2017/10/02 | Sergey Sharybin | Fix T52927: Compositor wrong scale when scale size input is connected to complex node |
rBb22b2c783d | 2017/10/04 | Sergey Sharybin | Fix T52982: Join operator with context override crashes Blender 2.79 |
rBc756787694 | 2017/10/06 | Sergey Sharybin | Fix T52940: VSE Glow Effect Strip on transparent images has no blur |
rB06ff970f27 | 2017/10/17 | Sergey Sharybin | Fix T53007: OpenSubdiv + transparency = artefact/crashes |
rBbfbcc5e581 | 2017/12/07 | Sergey Sharybin | Fix T53499: Cannot load DPX files |
rBa41fe949d8 | 2017/12/18 | Sergey Sharybin | Fix T53398: Surface deform modifier says that convex polygons are concave for… |
rBdf0ecd73af | 2017/12/22 | Sergey Sharybin | Subsurf: Avoid global lock for loops and orig index layers |
rB870840e8b7 | 2017/12/22 | Sergey Sharybin | Subsurf: Avoid possible use of partially initialized edge hash |
rB3ee2ed3049 | 2018/01/08 | Sergey Sharybin | Fix T53612: Blender crashes on CleanTracks with 'DELETE_SEGMENTS' and a disabled marker |
rB2dab6f499c1 | Sergey Sharybin | Mikkspace: Cleanup, reduce indentation level | |
rB3241905f40e | Sergey Sharybin | Fix T52818: Tangent space calculation is really slow for high-density mesh with degenerated topology | |
rBdb7a78a2be7 | Sergey Sharybin | Cycles: Fix compilation error with latest OIIO | |
rB42dff6cc2eb | Sergey Sharybin | Cycles: Fix compilation error with OIIO compiled against system PugiXML | |
rBd1a761c4d4c | Sergey Sharybin | Cycles: Fix compilation error of standalone application | |
rB2e8914549b6 | Sergey Sharybin | Cycles: Fix difference in image Clip extension method between CPU and GPU | |
rBa950af8e24d | Sergey Sharybin | Fix T53012: Shadow catcher creates artifacts on contact area | |
rBab1af38c74 | 2017/12/19 | Sergey Sharybin | Cycles: Fix crash opening user preferences after adding extra GPU |
rB55696b56d98 | Sergey Sharybin | Fix T53068: AMD Threadripper not working well with Blender | |
rB0a3fa9c25c9 | Arto Kitula | Fix missing SpinLock typedef on macOS | |
rB83d9f8e3796 | Stefan Werner | Compositor: Ensured 16 byte alignment for variables accessed by SSE instructions. | |
rBdf886b178c9 | Stefan Werner | Moved alignment attributes from my last commit to BLI_compiler_attrs.h for future use. | |
rB1febc858559 | Stefan Werner | Cycles: Workaround for performance loss with the CUDA 9.0 SDK. | |
rB58a15b2bfe7 | Stefan Werner | Cycles: Fixed compilation of CUDA kernels. Follow-up fix for my last commit. | |
rB0012d54a70 | 2017/10/29 | Sybren A. Stüvel | Alembic import: fixed mesh corruption when changing topology |
rB50f1c9a8af | 2017/12/22 | Sergey Sharybin | Task scheduler: Start with suspended pool to avoid threading overhead on push |
rB6efd58dd3e | 2017/12/22 | Sergey Sharybin | Task scheduler: Clarify why do we need an atomic add of 0 |
rB09aaee5640 | 2018/02/19 | Sergey Sharybin | Fix T53032: Image sequence works bad with Displace modifier |
rB9e707802c2 | 2018/02/21 | Sergey Sharybin | Depsgraph: Fix crash using --debug-depsgraph and --debug-depsgraph-no-threads |
EXCLUDED:
rBa51688d0b0 | 2017/10/12 | Bastien Montagne | Fix T53052: ID decrement error when deleting a scene, either python or GUI ==>> Depends on ID copy refactor, not in 2.79, not easily portable. |
rB77f300e2a92 | Brecht Van Lommel | Fix use of uninitialized memory in Cycles normal baking. | |
rBed7260071bc | Brecht Van Lommel | Fix EXR multilayer compositing result saving issues. | |
rBe8e92dffed | 2017/12/25 | Brecht Van Lommel | Fix T53607: Cycles normal map baking problem when there is no bump |
rB6a225a283e | 2017/12/29 | Brecht Van Lommel | Build: fix make deps OpenSubdiv build on Linux |
rBac934efc5e | 2017/12/30 | Brecht Van Lommel | Build: fix make deps TBB on Linux, older versions don't support GCC 7 |
rB0e59f2b256 | 2018/01/06 | Brecht Van Lommel | Fix T47212: incorrect luma coefficients for Luminance Key node |
rBd0cc5d8948 | 2018/01/11 | Philipp Oeser | Fix T53752: Draw curve fails w/ stylus |
rB43f33ea300 | 2017/12/11 | Sergey Sharybin | Node selection: Stop operator when mouse selection selected a node |
To be included:
(no clean cherry-pick for those remaining)
rBbb30ce0f0b | 2017/12/18 | Howard Trickey | Fix T53474, bevel glitchy with big objects. |
rB4838512e7d | 2017/12/13 | João Seixas | Fix T53404 - Python API documentation: UI Layout Emboss description wording |
rB941deaca7a | 2017/11/26 | Joshua Leung | Fix T53393: Change from 'd' key to 'draw' panel button causes pencil to be activated immediately instead of upon LMB |
To be considered???
rB25418be97e | 2018/01/03 | Arto Kitula | build deps: llvm new website download locations |
rBee49ee24c33 | Dalai Felinto | Fix: unselectable objects can be selected via the NLA editor | |
rB0c019a3ffc | 2017/09/21 | Joshua Leung | Fix T50450: Breakdowner doesn't work in Tweak Mode on translated NLA Strips |
rB96e84d002a | 2017/09/26 | Joshua Leung | Fix T52901: New Depsgraph - Driver using "self" needs reloading file to work |
rB262ddbfda0 | 2017/09/26 | Campbell Barton | Add missing header |
rBae72a9206e | 2017/10/20 | Joshua Leung | Fix T46163: NLA properties with drivers aren't displayed as having drivers |
rBc71f2f1404 | 2017/10/24 | Joshua Leung | Fix T53130: NLA Tweak (moved) Tracks + Alt+RMB Select does not work in Graph Editor |
rB61fe8e8acaf | Julian Eisel | Hide "Confirm on Release" button from transfor redo options] | |
rB57d7e5b6ee8 | Ray Molenkamp | Fix T42489 and T52936: Loading blend with minimized window results in crash or empty screen on windows. | |
rBfdd3d969a6 | 2018/01/10 | Campbell Barton | Fix T53491: Absolute tablet motion detection fails |
