2.79a release - addons #53684
Closed
opened 2018-01-03 12:33:44 +01:00 by Bastien Montagne · 15 comments
This task is status for addons repository for 2.79a release.
UP TO ea4245645c
Applied
1d9d466de8 2017/09/08 Maurice Raybaud (mauriceraybaud) *Fixed texture normal_factor regression *Fixed lighting attenuation for a…
435e6affc0 2017/09/17 Brendon Murphy (meta-androcto) viewport pies sculpt menu: Fix #52780
8f830f44e9 2017/09/18 Vuk Gardašević (lijenstina) Fix #52714: Dynamic Sky not working with localization enabled
b302fdf053 2017/09/19 Sergey Sharybin (sergey) Fix blender/blender#52822: Incorrect dimensions of imported svg files
b3c6d44409 2017/09/20 Bastien Montagne (mont29) Fix #52846: Wrong normals when importing FBX from Revit.
ce7685695e 2017/09/25 Campbell Barton (campbellbarton) Fix #52833: OBJ triangulate doesn't match viewport
8ca82b7d94 2017/09/26 nBurn (nBurn) Fix #52545: Have MeasureIt check for custom layers
cda6973adf 2017/09/26 Vuk Gardašević (lijenstina) 3D Viewport Pie Menus: Fix wrong label in preferences
9b8f850249 2017/09/26 Vuk Gardašević (lijenstina) Dynamic Context Menu: Disable Group Instance if there are no Groups
88f0d4f89e 2017/09/28 Vuk Gardašević (lijenstina) Display Tools: Fix particles issues with Fast Navigation
7cf00a0fb9 2017/09/30 Vuk Gardašević (lijenstina) Dynamic Context Menu: Fix issues with moving the object to a new layer
0ec1bacc4d 2017/10/07 Vuk Gardašević (lijenstina) 3D Viewport Pie Menus: Avoid empty Modes pie in some cases
9d7cfcd8a9 2017/10/07 Vuk Gardašević (lijenstina) Copy Attributes Menu: Add a message about needed selection, cleanup
e8f09a8e0b 2017/10/10 Bastien Montagne (mont29) Fix #52945: OBJ import - load_material_image - map_options not parsed correctly.
89285a88ab 2017/10/18 Bastien Montagne (mont29) Fix #53065: stupid animation linked to nothing in FBX file broke import.
5f8aaa2d4e 2017/10/23 Lukas Treyer (cnd) Wrap array access for width property in a if-statement to avoid errors with…
592493c6d9 2017/10/25 Lucio Rossi (luciorossi) #53019 fix paw toe bones following foot ctrl when IK_Stretch=0
e6ecb6a194 2017/10/25 Lucio Rossi (luciorossi) #53024 fix n-panel Switch rotation-pole not working for bones wo keys
6b065addaf 2017/10/30 Lucio Rossi (luciorossi) fix: Encode Widget btn not showing in Tools
560888f91b 2017/10/26 Campbell Barton (campbellbarton) system_demo_mode: correct hidden file skipping
0b286650b3 2017/10/31 Bastien Montagne (mont29) Fix #53202: Complex armature with bone constraints, FBX export bug.
fde4fe14b7 2017/10/31 Bastien Montagne (mont29) Add option to control FBX 'empty' type through a string custom property in…
c075629c95 2017/11/02 Campbell Barton (campbellbarton) Cleanup: redundant texture lookup
7a75719ec3 2017/11/02 Vuk Gardašević (lijenstina) Fix #53136: Make the .gpl palette import more robust
e00cbb80bc 2017/11/06 Bastien Montagne (mont29) Fix #53254: Fbx import assertion error on some Enum custom property.
5b02e6e1ac 2017/11/08 Bastien Montagne (mont29) ui_translate: make it resilient to ASAN errors at exit.
0ec059ad19 2017/11/27 Vuk Gardašević (lijenstina) HiRISE DTM Importer: Fix operator call through Python, minor cleanup
1473e69bb8 2017/12/05 Lucio Rossi (luciorossi) fix #53355: missing Rot2Pole switch operator when Rigify is disabled
ff687ae681 2017/12/06 Sybren A. Stüvel (sybren) Updated Blender ID add-on to version 1.4:
9077f67a5a 2017/12/06 Vuk Gardašević (lijenstina) Fix #53406: Avoid toggling visibility on Collision modifier
75ad0c4177 2017/12/06 Campbell Barton (campbellbarton) Fix easy lattice
2e3b7dafbc 2017/12/08 Adam Dominec (emu) io_export_paper_model: update to upstream 7fe2553 fix baking in both Cycles and…
6cdbffbc22 2017/12/15 Sybren A. Stüvel (sybren) Updated Blender ID add-on to version 1.4.1
9b5b837971 2017/12/19 Bastien Montagne (mont29) Fix for Fix (c): #52945: OBJ import - load_material_image - map_options not…
e6b81de7e1 2017/12/11 Lukas Treyer (cnd) Applying D2933: Adds support for elevation attribute for lwpolylines (code 38)
4bac8438df 2018/01/06 stephen leger (stephen_leger) fix #53706 : write cmd script into writeable temp folder
808565a770 2018/01/08 Bastien Montagne (mont29) Fix #53707: Error on export FBX object [PointLighs].
29ae03c572 2018/01/22 Bastien Montagne (mont29) Fix #53841: Can not import .obj or .fbx generated from Marvelous Designer
bfab29085c 2018/02/13 Vuk Gardašević (lijenstina) Network Renderer: redirecting Documentation wiki link
cf60d1ad47 2018/01/22 Bastien Montagne (mont29) Comment out some features in Ivy gen, for 2.79a only (not in master).
62e685cc07 2018/02/13 Bastien Montagne (mont29) Comment another crashing menu entry in mesh extra tools addon, for 2.79a.
EXCLUDED:
267662e07a 2017/09/20 Bastien Montagne (mont29) Fix #52839: "Copy Render Settings" doesn't work.
1f2b515623 2017/12/05 Lucio Rossi (luciorossi) fix #53356: update bbone_in bbone_out props to bbone_easein bbone_easeout ==>> Should not be necessary in 2.79?
3dc0ceb198 2018/01/22 Bastien Montagne (mont29) Fix #53812: FBX import fails with long custom property names.
To be backported.
eeabcc9c55 2017/10/15 Vuk Gardašević (lijenstina) Bool Tool: Add missing bl_idname to VIEW3D_MT_booltool_menu
Might be considered ???
2edd24a4e6 2017/09/29 Florian Meyer (testscreenings) Fix #51503 Added support for Cycles image textures
dfdf55714c 2017/10/02 Vuk Gardašević (lijenstina) Fix #52973: Support data dimensions types, restore global_undo
c21b887882 2017/11/17 Sergey Sharybin (sergey) Add addon to help debugging new dependency graph
f60ec960de 2017/12/07 stephen leger (stephen_leger) Move presets to user writeable folder when rendering thumbs
e6b81de7e1 2017/12/11 Lukas Treyer (cnd) Applying D2933: Adds support for elevation attribute for lwpolylines (code 38)…
05688be3be 2017/12/21 Sergey Sharybin (sergey) Depsgrapg debug: Add buttons to show evaluation statistics
ea4245645c 2018/01/06 Vuk Gardašević (lijenstina) Fix #53579: Move the settings into a Tools Panel, use wm property group
dc6704ab42 2018/01/25 Philipp Oeser (lichtwerk) fix #53766: MeasureIt measurements not appearing on all layers an object exists on
87579bd164 2018/01/26 Philipp Oeser (lichtwerk) A.N.T. Landscape should not be operating in edit mode
This task is status for addons repository for 2.79a release. UP TO ea4245645c # Applied |1d9d466de8| 2017/09/08| Maurice Raybaud (mauriceraybaud) |*Fixed texture normal_factor regression *Fixed lighting attenuation for a… | -- | -- | -- | -- | |435e6affc0| 2017/09/17| Brendon Murphy (meta-androcto) |viewport pies sculpt menu: Fix #52780 |8f830f44e9| 2017/09/18| Vuk Gardašević (lijenstina) |Fix #52714: Dynamic Sky not working with localization enabled |b302fdf053| 2017/09/19| Sergey Sharybin (sergey) |Fix blender/blender#52822: Incorrect dimensions of imported svg files |b3c6d44409| 2017/09/20| Bastien Montagne (mont29) |Fix #52846: Wrong normals when importing FBX from Revit. |ce7685695e| 2017/09/25| Campbell Barton (campbellbarton) |Fix #52833: OBJ triangulate doesn't match viewport |8ca82b7d94| 2017/09/26| nBurn (nBurn) |Fix #52545: Have MeasureIt check for custom layers |cda6973adf| 2017/09/26| Vuk Gardašević (lijenstina) |3D Viewport Pie Menus: Fix wrong label in preferences |9b8f850249| 2017/09/26| Vuk Gardašević (lijenstina) |Dynamic Context Menu: Disable Group Instance if there are no Groups |88f0d4f89e| 2017/09/28| Vuk Gardašević (lijenstina) |Display Tools: Fix particles issues with Fast Navigation |7cf00a0fb9| 2017/09/30| Vuk Gardašević (lijenstina) |Dynamic Context Menu: Fix issues with moving the object to a new layer |0ec1bacc4d| 2017/10/07| Vuk Gardašević (lijenstina) |3D Viewport Pie Menus: Avoid empty Modes pie in some cases |9d7cfcd8a9| 2017/10/07| Vuk Gardašević (lijenstina) |Copy Attributes Menu: Add a message about needed selection, cleanup |e8f09a8e0b| 2017/10/10| Bastien Montagne (mont29) |Fix #52945: OBJ import - load_material_image - map_options not parsed correctly. |89285a88ab| 2017/10/18| Bastien Montagne (mont29) |Fix #53065: stupid animation linked to nothing in FBX file broke import. |5f8aaa2d4e| 2017/10/23| Lukas Treyer (cnd) |Wrap array access for width property in a if-statement to avoid errors with… |592493c6d9| 2017/10/25| Lucio Rossi (luciorossi) |#53019 fix paw toe bones following foot ctrl when IK_Stretch=0 |e6ecb6a194| 2017/10/25| Lucio Rossi (luciorossi) |#53024 fix n-panel Switch rotation-pole not working for bones wo keys |6b065addaf| 2017/10/30| Lucio Rossi (luciorossi) |fix: Encode Widget btn not showing in Tools |560888f91b| 2017/10/26| Campbell Barton (campbellbarton) |system_demo_mode: correct hidden file skipping |0b286650b3| 2017/10/31| Bastien Montagne (mont29) |Fix #53202: Complex armature with bone constraints, FBX export bug. |fde4fe14b7| 2017/10/31| Bastien Montagne (mont29) |Add option to control FBX 'empty' type through a string custom property in… |c075629c95| 2017/11/02| Campbell Barton (campbellbarton) |Cleanup: redundant texture lookup |7a75719ec3| 2017/11/02| Vuk Gardašević (lijenstina) |Fix #53136: Make the .gpl palette import more robust |e00cbb80bc| 2017/11/06| Bastien Montagne (mont29) |Fix #53254: Fbx import assertion error on some Enum custom property. |5b02e6e1ac| 2017/11/08| Bastien Montagne (mont29) |ui_translate: make it resilient to ASAN errors at exit. |0ec059ad19| 2017/11/27| Vuk Gardašević (lijenstina) |HiRISE DTM Importer: Fix operator call through Python, minor cleanup |1473e69bb8| 2017/12/05| Lucio Rossi (luciorossi) |fix #53355: missing Rot2Pole switch operator when Rigify is disabled |ff687ae681| 2017/12/06| Sybren A. Stüvel (sybren) |Updated Blender ID add-on to version 1.4: |9077f67a5a| 2017/12/06| Vuk Gardašević (lijenstina) |Fix #53406: Avoid toggling visibility on Collision modifier |75ad0c4177| 2017/12/06| Campbell Barton (campbellbarton) |Fix easy lattice |2e3b7dafbc| 2017/12/08| Adam Dominec (emu) |io_export_paper_model: update to upstream 7fe2553 fix baking in both Cycles and… |6cdbffbc22| 2017/12/15| Sybren A. Stüvel (sybren) |Updated Blender ID add-on to version 1.4.1 |9b5b837971| 2017/12/19| Bastien Montagne (mont29) |Fix for Fix (c): #52945: OBJ import - load_material_image - map_options not… |e6b81de7e1| 2017/12/11| Lukas Treyer (cnd) |Applying [D2933](https://archive.blender.org/developer/D2933): Adds support for elevation attribute for lwpolylines (code 38) |4bac8438df| 2018/01/06| stephen leger (stephen_leger) |fix #53706 : write cmd script into writeable temp folder |808565a770| 2018/01/08| Bastien Montagne (mont29) |Fix #53707: Error on export FBX object [PointLighs]. | 29ae03c572 | 2018/01/22 | Bastien Montagne (mont29) | Fix #53841: Can not import .obj or .fbx generated from Marvelous Designer | bfab29085c | 2018/02/13 | Vuk Gardašević (lijenstina) | Network Renderer: redirecting Documentation wiki link | | | | cf60d1ad47 | 2018/01/22 | Bastien Montagne (mont29) | Comment out some features in Ivy gen, for 2.79a only (not in master). | 62e685cc07 | 2018/02/13 | Bastien Montagne (mont29) | Comment another crashing menu entry in mesh extra tools addon, for 2.79a. ---------------------------------------------- # EXCLUDED: | 267662e07a| 2017/09/20| Bastien Montagne (mont29) |Fix #52839: "Copy Render Settings" doesn't work. | -- | -- | -- | -- | | 1f2b515623| 2017/12/05| Lucio Rossi (luciorossi) |fix #53356: update bbone_in bbone_out props to bbone_easein bbone_easeout ==>> Should not be necessary in 2.79? | 3dc0ceb198 | 2018/01/22 | Bastien Montagne (mont29) | Fix #53812: FBX import fails with long custom property names. ---------------------------------------------- # To be backported. |eeabcc9c55| 2017/10/15| Vuk Gardašević (lijenstina) |Bool Tool: Add missing bl_idname to VIEW3D_MT_booltool_menu | -- | -- | -- | -- | ---------------------------------------------- # Might be considered ??? |2edd24a4e6| 2017/09/29| Florian Meyer (testscreenings) |Fix #51503 Added support for Cycles image textures | -- | -- | -- | -- | |dfdf55714c| 2017/10/02| Vuk Gardašević (lijenstina) |Fix #52973: Support data dimensions types, restore global_undo |c21b887882| 2017/11/17| Sergey Sharybin (sergey) |Add addon to help debugging new dependency graph |f60ec960de| 2017/12/07| stephen leger (stephen_leger) |Move presets to user writeable folder when rendering thumbs |e6b81de7e1| 2017/12/11| Lukas Treyer (cnd) |Applying [D2933](https://archive.blender.org/developer/D2933): Adds support for elevation attribute for lwpolylines (code 38)… |05688be3be| 2017/12/21| Sergey Sharybin (sergey) |Depsgrapg debug: Add buttons to show evaluation statistics | ea4245645c | 2018/01/06 | Vuk Gardašević (lijenstina) | Fix #53579: Move the settings into a Tools Panel, use wm property group | dc6704ab42 | 2018/01/25 | Philipp Oeser (lichtwerk) | fix #53766: MeasureIt measurements not appearing on all layers an object exists on | 87579bd164 | 2018/01/26 | Philipp Oeser (lichtwerk) | A.N.T. Landscape should not be operating in edit mode
Author
Owner
Added subscriber: @mont29
Member
Added subscribers: @LucioRossi, @JulienDuroure
Member
This one must be backported too :
@LucioRossi, can you confirm it ?
This one must be backported too : 1473e69bb8 2017/12/05 Lucio Rossi (luciorossi) fix #53355: missing Rot2Pole switch operator when Rigify is disabled @LucioRossi, can you confirm it ?
@JulienDuroure yes it should be backported thank you!
Added subscriber: @VukGardasevic
9d7cfcd8a9 2017/10/07 Copy Attributes Menu: Add a message about needed selection, cleanup fixes bad menu calls. 3 menus were still code generated classes and listed in the bpy.types but cannot be accessed in the menu, still lingering around as they are not properly registered. The register part was removed in the previous commit to the add-on as it caused issues.
75ad0c4177 2017/12/06 Fix easy lattice solves a Blender crash when adding the lattice in Local View.
0ec059ad19 2017/11/27 HiRISE DTM Importer: Fix operator call through Python, minor cleanup Solves 2 crashes: when calling the operator through script / python console with bpy.ops.import.pds_dtm as .import. is a reserved keyword and a crash with Reload operator wrong context
9077f67a5a 2017/12/06 Fix #53406: Avoid toggling visibility on Collision modifier Solves issue with the Collision modifier being disabled without any feedback. Not essential, but can cause confusion for users
7a75719ec3 2017/11/02 Fix #53136: Make the .gpl palette import more robust The previous code loaded all the folder files in the preset menu apart from reading the palette file only in a specific configuration
88f0d4f89e 2017/09/28 Display Tools: Fix particles issues with Fast Navigation Particles navigation was broken in 2.79 as it didn't restore the particles settings properly upon exiting
These commits should be safe to include.
|9d7cfcd8a9| 2017/10/07 Copy Attributes Menu: Add a message about needed selection, cleanup fixes bad menu calls.| 3 menus were still code generated classes and listed in the bpy.types but cannot be accessed in the menu, still lingering around as they are not properly registered. The register part was removed in the previous commit to the add-on as it caused issues. | -- | -- | -- | |75ad0c4177| 2017/12/06 Fix easy lattice | solves a Blender crash when adding the lattice in Local View. |0ec059ad19 |2017/11/27 HiRISE DTM Importer: Fix operator call through Python, minor cleanup| Solves 2 crashes: when calling the operator through script / python console with `bpy.ops.import.pds_dtm` as `.import.` is a reserved keyword and a crash with Reload operator wrong context |9077f67a5a| 2017/12/06 Fix #53406: Avoid toggling visibility on Collision modifier| Solves issue with the Collision modifier being disabled without any feedback. Not essential, but can cause confusion for users |7a75719ec3| 2017/11/02 Fix #53136: Make the .gpl palette import more robust| The previous code loaded all the folder files in the preset menu apart from reading the palette file only in a specific configuration |88f0d4f89e| 2017/09/28 Display Tools: Fix particles issues with Fast Navigation| Particles navigation was broken in 2.79 as it didn't restore the particles settings properly upon exiting These commits should be safe to include.
Commited the fix ea4245645c. If it is too intrusive for 2.79a the operator calls in the operator draw function should be commented out. The fix should work making a more logical add-on workflow, however it all depends if it is acceptable for inclusion at this stage.
Author
Owner
Would be a last-minute, rather heavy, nearly untested change for some non-critical issue… So I would really rather not include that type of commit in 2.79a.
> In #53684#477844, @VukGardasevic wrote: > Commited the fix ea4245645c. If it is too intrusive for 2.79a the operator calls in the operator draw function should be commented out. The fix should work making a more logical add-on workflow, however it all depends if it is acceptable for inclusion at this stage. Would be a last-minute, rather heavy, nearly untested change for some non-critical issue… So I would really rather not include that type of commit in 2.79a.
No problem:)
Could just the operator calls be commented out, since those crash Blender when accessed from the F6 menu? If people complain we can point out to the master version:)
> In #53684#477909, @mont29 wrote: >> In #53684#477844, @VukGardasevic wrote: >> Commited the fix ea4245645c. If it is too intrusive for 2.79a the operator calls in the operator draw function should be commented out. The fix should work making a more logical add-on workflow, however it all depends if it is acceptable for inclusion at this stage. > > Would be a last-minute, rather heavy, nearly untested change for some non-critical issue… So I would really rather not include that type of commit in 2.79a. No problem:) Could just the operator calls be commented out, since those crash Blender when accessed from the F6 menu? If people complain we can point out to the master version:)
Member
Added subscriber: @StephenLeger
Member
Commited fix 4bac8438df for critical issue #53706
Author
Owner
Done, thanks.
> In #53684#477927, @StephenLeger wrote: > Commited fix 4bac8438df for critical issue #53706 Done, thanks.
If possible, this small Documentation wiki fix can be included too.
bfab29085c
Thanks.
If possible, this small Documentation wiki fix can be included too. bfab29085c Thanks.
Author
Owner
bfab29085c
Thanks.
Done
> In #53684#484479, @VukGardasevic wrote: > If possible, this small Documentation wiki fix can be included too. > bfab29085c > > Thanks. Done
Member
Aaron Carlisle self-assigned this 2020-01-04 20:31:19 +01:00
6 Participants
Reference: blender/blender-addons#53684
