Rendering with Volume Absorption aborts with CUDA Error
XPS 15 9560
Win 10 / GTX 1050
Official 2.79 Release and 2.79.0-cacba95
Broken: both
Worked: negative
Here on the XPS and a Ryzen Threadripper with GTX 1080Ti the render of the attached scene will be stopped with a CUDA error:
Launch failed in cuCTXSynchronize(), line 1762
Disconnecting the Volume Absorption node will fix this. Conclusion: Volume Absorption is broken.
Load the attached scene and press F12 for render.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.Jan 11 2018, 11:08 PM
I couldn't reproduce a crash on Linux with a GTX 1080, will test on Windows later.
Last night it crashed for me (Linux Mint 18.3, 12GB RAM, GTX780 3GB), but now with the very current master it works:
Maybe it's hard to reproduce, I'll give it some more shots.
Gave it 10 more tries, no crash. It also works reliably with the brand new "Transparent Glass" feature. :)
The attached simple scene seems to work with the latest release. But keep in mind that I also could render this before but later the error appeared. Maybe its a random error caused by a specific situation?
I've added another scene "RB0112_6981_Arial_Intruder_v03.zip" with very high Branched Path Tracing samples. This gave me again a CUDA error with the actual Saturday, 13.01.18 build. I restarted Blender and the simple scene could be rendered in hybrid mode.
Now I reloaded the Aerial Intruder scene and set AA to 64 and all other passes to 1. This will render now without a CUDA error.
I did now a couple of tests with the latest build of today. GPU rendering with my scenes is definitely broken.
BTW: the new Transparent Glass option is great. So useful. Good job ... as always.
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Feb 10 2020, 5:20 PM
This file reqires 12h of rendering time on my machine. Please submit simplified file if possible.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
Aaron Carlisle (Blendify) closed this task as Resolved.Feb 18 2020, 7:29 PM
Aaron Carlisle (Blendify) claimed this task.
