Forward Cycling Improvements
Closed, ArchivedPublicPATCH
This patch adds options to customize which axes, and which, are used for forward cycling. When a user types in the name of an offset bone, three new options appear in the NLA NKEY panel: Use X, Use Y, and Use Z. If any of these are toggled, the automatically detected single-axis used for forward cycling is disabled, and instead it uses the axes enabled by these buttons.
E.g. if your doing a stair stepping cycle, you can select Y (or X) and Z; if your doing something that's diagonal you can select all three, X Y and Z. On the other hand, if the automatic single-axis picking isn't working for some reason on your armature, you can select the axis manually.
Joe
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Jan 19 2007, 10:31 AM
