NP Station #53961
Closed
opened 2018-01-31 12:23:03 +01:00 by Srinivasan M K · 5 comments
OS - Windows 7 Professional 64- bit
RAM - 4.00 GB
Graphics Card - Nvidia GeForce GT 610
Broken : 2.79 5bd8ac9
Worked :
File "C;\xxxxxx\xxxx\xxxx\xxxx\xxx\Blender\2.79\scripts\addons\np_point_move.py", line83,in
add-on Imported but not enabling gives error like above
file attached 20180131 - Importing DXF .blend
**System Information** OS - Windows 7 Professional 64- bit RAM - 4.00 GB Graphics Card - Nvidia GeForce GT 610 **Blender Version** Broken : 2.79 5bd8ac9 Worked : Traceback (most recent call last): File "C;\xxxxxx\xxxx\xxxx\xxxx\xxx\Blender\2.79\scripts\addons\np_point_move.py", line83,in<Module> **Exact steps for others to reproduce the error** add-on Imported but not enabling gives error like above file attached [20180131 - Importing DXF .blend](https://archive.blender.org/developer/F2057301/20180131_-_Importing_DXF_.blend) ![NP Station Error.png](https://archive.blender.org/developer/F2057305/NP_Station_Error.png)
Author
Added subscriber: @Srinivasan
Added subscriber: @VukGardasevic
Vuk Gardašević self-assigned this 2018-01-31 13:20:30 +01:00
From the error in the image provided seems that the add-on is not properly installed.
Remove the NP station related files created during the unpacking from the blender config path (the one that contains AppData ) and unpack it keeping the folder structure intact.
If you want to see how it looks like, you can check the appropriate windows daily build from https://builder.blender.org/download/ (first section), unpack the zip file and check the \2.79\scripts\addons_contrib\np_station\ folder.
The add-on install has to contain all the files listed there under the folder named np_station.
If there are other issues related to the enabling of add-on please let us know so the task can be reopened.
Closing as archived.
From the error in the image provided seems that the add-on is not properly installed. Remove the NP station related files created during the unpacking from the blender config path (the one that contains `AppData` ) and unpack it keeping the folder structure intact. If you want to see how it looks like, you can check the appropriate windows daily build from https://builder.blender.org/download/ (first section), unpack the zip file and check the `\2.79\scripts\addons_contrib\np_station\` folder. The add-on install has to contain all the files listed there under the folder named `np_station`. If there are other issues related to the enabling of add-on please let us know so the task can be reopened. Closing as archived.
Author
Dear Sir,
Thanks it Works !!!
Dear Sir, Thanks it Works !!!
2 Participants
Reference: blender/blender-addons#53961
