Blender 2.79a rc gpu vega 56 rendering failed
Windows 10 proffesional Radeon Vega 56 driver 18.1.1
Broken: Blender 2.79a rc
Worked: 2.79 1eeb846
**Gpu rendering not working on Radeon Vega 56 test scene pavillon_barcelone_v1.2,
Render fails on any scene with the same console output...
console output:
Device init success
Compiling OpenCL program split
OpenCL build failed with error CL_BUILD_PROGRAM_FAILURE, errors in console.
OpenCL program split build output: source\kernel/geom/geom_object.h:173:48: error: no member named 'lamp' in 'struct ShaderData'
Transform tfm = lamp_fetch_transform(kg, sd->lamp, false);
source\kernel/kernel_shadow.h:470:49: warning: use of logical '&&' with constant operand
if(!kernel_data.integrator.transparent_shadows &&
source\kernel/kernel_shadow.h:470:49: note: use '&' for a bitwise operation
source\kernel/kernel_shadow.h:470:49: note: remove constant to silence this warning
1 warning and 1 error generated.
error: Clang front-end compilation failed!
Frontend phase failed compilation.
Error: Compiling CL to IR**
