Transformation orientation stays stuck in Global #54018
Closed
opened 2018-02-07 14:15:26 +01:00 by Eric · 6 comments
Windows10
GTX 1060
v2.79 5bd8ac9
Over time, while working in Edit Mode manipulating mesh, have to close Blender because Transformation orientation stays stuck in Global.
No specific steps available other than continuous use of manipulator then suddenly it gets stuck in Global mode, occurs with any file.
eg:
Manipulator in Normal mode shows translate arrows correctly but when it is pulled it translates in the Global angle. The side of a sphere Z is away from center in Normal but it pulls in global Z upwards.
Windows10 GTX 1060 v2.79 5bd8ac9 Over time, while working in Edit Mode manipulating mesh, have to close Blender because Transformation orientation stays stuck in Global. No specific steps available other than continuous use of manipulator then suddenly it gets stuck in Global mode, occurs with any file. eg: Manipulator in Normal mode shows translate arrows correctly but when it is pulled it translates in the Global angle. The side of a sphere Z is away from center in Normal but it pulls in global Z upwards.
Author
Added subscriber: @JJLee
Added subscriber: @zeauro
  • Does it happen with 2.79a Release Candidate ? It can be downloaded, here .
  • Does it happen with a specific project or with default cube ? Did you try to load factory settings ?
If you find an error in Blender you need to report exactly how to redo the bug. However this is not a bug report we can handle usefully.
Nobody will start an endless session of modeling just to try to reproduce the bug.
So, try to investigate it a little bit more. Try to spot after how many minutes, steps of modeling session or which operators, it happens.
Attending for precisions, I mark this report as incomplete.
- Does it happen with 2.79a Release Candidate ? It can be downloaded, [here ](https://www.blender.org/download/). - Does it happen with a specific project or with default cube ? Did you try to load factory settings ? # If you find an error in Blender you need to report exactly how to redo the bug. However this is not a bug report we can handle usefully. Nobody will start an endless session of modeling just to try to reproduce the bug. So, try to investigate it a little bit more. Try to spot after how many minutes, steps of modeling session or which operators, it happens. ``` ``` Attending for precisions, I mark this report as incomplete.
ronan ducluzeau self-assigned this 2018-02-19 12:32:36 +01:00
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
Author
I'm using it now and if it occurs with 2.79a I'll update this post.
2 Participants
Reference: blender/blender#54018
