Rendering Animation
Newest Version
Broken: (example: 2.69.7 4b206af, see splash screen)
When attempting to render an animation, it says 'could open file to write image.' I'm also unable to save and export this animation.
Click render animation
I'm unable to render and save the animation. It says 'could not save file to write image.' It also says I'm unable to save and export the animation.
Hello.
What is your operating system, graphics card model, and Blender version?
Did you check the render output formats and path? Have you saved your .blend file first? Did you checked you have the reading and writing permissions on the output folder?
ronan ducluzeau (zeauro) triaged this task as Incomplete priority.Feb 13 2018, 6:43 PM
I can not reproduce.
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
LOLock remarks are pertinent. Please give an answer for each one.
Marking as "Incomplete" until the requested information/data is provided.
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
