Object texture mapping using only 1/4 of the object surface #54081
Reference: blender/blender#54081
Using an empty as a reference object to specify the texture coordinates only results in 1/4 of the area being used.
The empty is 3/4 bigger than the area that's being textured.
Best open the blend file to see for your self.
Blender 2.79 on Windows 8
Added subscriber: @NielsPhilipsen
Added subscriber: @Sergey
There is no file attached.
BlenderBug_object_texture_mapping.blend
Fixed
Added subscriber: @candreacchio
Not a bug. +U and +V are also correct but when it goes -U and -V, its being limited off by the extrapolation of the image textures (clip instead of repeat)
Added subscriber: @brecht
It makes a bit more sense with the default empty cross shape, then the image is in the corner.
Arguably it would have been better to center it by default, but this would break backwards compatibility and I don't think it's serious enough to make that kind of change.
The texture that you can see in the render is in fact the entire texture, its not being cut off its being scaled. I will upload another blendfile with a blurry circle texture, this will better illustrate the problem.
The expected behaviour would be to have the texture fit within the bounds of the empty, not just 1/4th of the bounds. This was also the original behaviour of using an empty in the materials for the older Internal renderer.
Pitty it's already archived.
Placing decals on materials was more intuitive with the old behaviour.
