File Output node doesn't keep layer names when switched to Multilayer EXR #54182
5 Participants
Reference: blender/blender#54182
Win10 64bit
Broken: 2.79
Open file, change file type in File Output node from PNG to Multilayer EXR -> names set to default, changing to others works good.
Input_names.blend
Added subscriber: @SergeL
#72246 was marked as duplicate of this issue
Added subscriber: @Jeroen-Bakker
Layer names and file subpaths are not interchangeable.
When Multilayer OpenEXR is selected the
layer name
is rendered next to the socket.For the other file types the
File Subpath
is rendered next to the socket.Hence when switching different names are displayed. They are not set back to default.
Added subscriber: @lichtwerk
Like @Jeroen-Bakker said:
layer name
andFile Subpath
are not interchangable.A
File Output
node comes with one input by default (which is called "Image")What happens when you
Add Input
for the File Output node is that unique new names get reserved for a newlayer
and a newFile Subpath
So you have a new File Subpath called "Image_001" and a new layer called "Image_001"
When you rename one of them, the other wont get synched
Same is true for the reverse btw.:
If you switch to MultilayerEXR first, add a layer, rename it and the switch to PNG, it's also not in sync
I dont think this is a bug, more of a TODO (if desired at all), but what could be done is whenever one of
NodeOutputFileSlotFile.path
orNodeOutputFileSlotLayer.name
gets changed, find the corresponding other and change it accordingly as well...@Jeroen-Bakker: think this is desireable? (could work on a patch then)
Added subscribers: @3di, @JacquesLucke
@JacquesLucke: feel free to change the subtype to whatever you seem fitting...
Added subscriber: @filibis
