Pricipled BSDF doesn't allow negative or above 1 colors for its specular/metallic part #54218
Reference: blender/blender#54218
Kubuntu 16.04.3 kernel 4.10, AMDGPUpro 17.50 (legacy opecl)
CPU AMD R7 1700
GPU AMD Rx 480 8gb
Broken: 2.79.2
Worked: using regular glossy shader.
Pricipled BSDF doesn't allow negative colors for its specular part, so when we add the negative principled shader with the positive one it should render a black object but instead, it's only rendering the positive shader.
I tested the diffuse, subsubscattering and transmission parts of the principled shader and only the specular one it's not allowing the negative colors or above 1, in other words only allowing clampled colors between 0 and 1.
negative.blend
Added subscriber: @iszotic
Pricipled BSDF doesn't allow negative colors for its specular/metallic partto Pricipled BSDF doesn't allow negative or above 1 colors for its specular/metallic partAdded subscriber: @brecht
I can confirm that, though using negative base colors is not supported at all for the Principled BSDF. It combines the various components in a physically based way and negative values don't make much sense in that context. The proper solution may not be to support negative values but to clamp them away, I need to look into it further.
Added subscriber: @EAW
Note: this is only the case for Cycles.
Using EEVEE (which wasn't in Blender at the time of this report), it is possible to create a negative color using the a value input node and combine RGB node, that will then create a specular black sphere following the above steps.
