Blender 2.79a crashes immediately on Undo Mask (Sculpt mode)
Windows 7 Ultimate x64. Titan X graphic card.
Broken: 2.79a, mask on sculpt mode
Blender crashes when you invert the mask areas and "undo" the changes you did into the last masked area.
Make a cube, sculpt anything. Press "M" to go into mask mode, paint an area. Invert the mask
Sculpt or modify anything inside the mask, Invert the mode (alt+M) and click CTRL+Z. Blender crashes.
LazyDodo (LazyDodo) triaged this task as Incomplete priority.Mar 16 2018, 10:25 PM
Can't seem to reproduce, any chance you can attach a sample file that'll show the problem with a minimal amount of steps?
Also cannot reproduce this. Could you upload your example file?
Does this also happen when you start blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not)?
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
