Problem with linked objects / texture coordinates
Closed, DuplicatePublic
Win10 x64 and Linux Mint 18.3
Broken: 2.79a and all current master builds. Probably all versions of Blender.
Worked: none
I have a simple object with a texture on it. The object itself doesn't have UVs as I use a "Texture Coordinate" node set to "Object" to generate the UV vector. The object that I reference is a simple empty.
All works as expected. But if I link these 2 objects as a group and translate the group, the texture doesn't move accordingly. Just like the empty's position wasn't updated although it's in the group that gets moved.
  • Download the 2 blend files (one contains the group to link, the other is just a simple master scene to link the group and render it) and put them both in the same directory.
  • Open "Master_Scene_v01.blend" and press SHIFT+Z to set the viewport to "Rendered" mode. A simple black plane with the word "Text" appears.
  • Now grab the "Textured_Plane" object and move it. The texture stays where it is and doesn't move with the plane.
I already tried different kinds of parenting but to no avail.
first note: doesnt have to be linked to a different file afaict, adding a group instance in the LIB_Object_v01.blend and moving that will show the same.
Having a closer look.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Feb 1 2019, 3:25 PM
This is still an issue in 2.8.
@Brecht Van Lommel (brecht) who to assign to (if any at this point)?
