Render crash with simple object only in debug build
5820K Windows10 GTX 970
Latest local build from master - date 16/03/2018
Render throws exception in debug build with very simple mesh - with adaptive subdivision
Problem appears to be in mesh_subdivsion.cpp
Line 193 int num_local_points = patch_table->GetNumLocalPoints();
returns zero
which means length of verts array is not increased and so
Line 207 patch_table->ComputeLocalPointValues(&verts[0], &verts[num_refiner_verts]);
fails because num_refiner_verts is greater than length of array (last element is num_refiner_verts-1)
Hope that helps.
Run debug version.
Load attached scene
Hit F12 to render
LazyDodo (LazyDodo) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Mar 16 2018, 9:36 PM
can confirm the issue, @Mai Lavelle (maiself) mind taking a peek here?
Hi,
Thanks for the changes/ However, the basic test scene is still crashing for me in Debug,
Line 209
Problem is num_local_points is zero so length of array set in line 195..
verts.resize(num_refiner_verts + num_local_points);
..is equal to num_refiner_points
Therefore line 209 fails because &verts[num_refiner_verts] is outside bounds of array.
Oops, used the wrong variable, will commit a fix shortly.
