Memory Leak closing from menu #54371
Closed
opened 2018-03-20 11:48:57 +01:00 by Antonio Vazquez · 8 comments
Windows 64 bits - Blender 2.8 branch - Compiled with last source code at 11:45 Today
To reproduce:
  1. Start from cmd with factory defaults.
  2. Close Blender using Quit menu option
  3. See a memory leak of huge ammount (the number looks totally wrong)
Try again:
  2. Close Blender using window top right close icon (X)
  3. Blender quits with no memory leak
Log of the command window: P639
Trace P640
Windows 64 bits - Blender 2.8 branch - Compiled with last source code at 11:45 Today To reproduce: 1) Start from cmd with factory defaults. 2) Close Blender using Quit menu option 3) See a memory leak of huge ammount (the number looks totally wrong) Try again: 1) Start from cmd with factory defaults. 2) Close Blender using window top right close icon (X) 3) Blender quits with no memory leak Log of the command window: [P639](https://archive.blender.org/developer/P639.txt) Trace [P640](https://archive.blender.org/developer/P640.txt)
Author
Member
Added subscriber: @antoniov
Author
Member
Added subscriber: @dfelinto
Author
Member
This is the window that you can see when close using Quit menu option.
This is the window that you can see when close using Quit menu option. ![image.png](https://archive.blender.org/developer/F2472288/image.png)
Added subscriber: @VukGardasevic
Is this similar to #48027?
Edit: After some testing the issue is still present in 2.80 build 04b8b1a167 on Linux.
Changing the INFO_MT_file entry to use layout.operator_context = 'INVOKE_AREA' seems to avoid the issue like it does for 2.79 in the previous task.
Is this similar to #48027? Edit: After some testing the issue is still present in 2.80 build `04b8b1a167` on Linux. Changing the INFO_MT_file entry to use layout.operator_context = 'INVOKE_AREA' seems to avoid the issue like it does for 2.79 in the previous task.
Member
Added subscribers: @fclem, @JulianEisel
Member
Doubt they are related, this issue happens within the draw-manager.
Had a ASan crash about this, 8a9be95cfb should fix it though. @fclem would have been easy to catch this if you compiled with ASan ;P
Assume this is fixed now.
Doubt they are related, this issue happens within the draw-manager. Had a ASan crash about this, 8a9be95cfb should fix it though. @fclem would have been easy to catch this if you compiled with ASan ;P Assume this is fixed now.
Member
Julian Eisel self-assigned this 2018-03-20 15:17:55 +01:00
Reference: blender/blender#54371
