Unsupported GCN cards available to select for Cycles
Hello. I have rendering problem using GPU Compute. GPU compute is slower that CPU and it's incorrect. On the picture you can see how it's look like. Cannot render even simply models. I have AMD radeon R5 M330 2GB graphic card (CPU Intel core i5). I'm using the last version (downloaded today).
Juan Pablo Montoya (onomatozie) triaged this task as Normal priority.
Juan Pablo Montoya (onomatozie) created this object with edit policy "All Users".
Mai Lavelle (maiself) closed this task as Invalid.Mar 23 2018, 3:29 AM
Mai Lavelle (maiself) claimed this task.
It looks like your GPU is from GCN 1 generation. Its unfortunate, but support for those cards had to be dropped. Your card shouldn't have been available to select for GPU rendering, did you enable debug mode? This mode isn't meant for regular use, and cant be expected to function properly. If you didn't enable debug mode and were still able to select your card then that would be a bug we should fix.
See AMD OpenCL sections here for more info:
https://docs.blender.org/manual/en/dev/render/cycles/gpu_rendering.html
https://wiki.blender.org/index.php/Dev:Source/Render/Cycles/OpenCL#Supported_AMD_Cards
Also please don't triage reports your self, leave that to someone else.
I'm not using debug mode but I can choose my graphic card in system setting. But as You said it's first GCN generation.
Mai Lavelle (maiself) renamed this task from Incorrect render using GPU Compute to Unsupported GCN cards available to select for Cycles.Mar 24 2018, 2:15 AM
Mai Lavelle (maiself) reopened this task as Open.
Mai Lavelle (maiself) lowered the priority of this task from Normal to Needs Information from User.Mar 24 2018, 2:18 AM
Could you please find and run the program clinfo and attach the output, it will help in figuring out why your card is listed when it shouldn't be.
output from clinfo:
Preferred vector width int: 1
Preferred vector width long:                   1
Preferred vector width float:                  1
Preferred vector width double:                 1
Native vector width char:                      32
Native vector width short:                     16
Native vector width int:                       8
Native vector width long:                      4
Native vector width float:                     8
Native vector width double:                    4
Max clock frequency:                           2200Mhz
Address bits:                                  64
Max memory allocation:                         2125058048
Image support:                                 Yes
Max number of images read arguments:           480
Max number of images write arguments:          480
Max image 2D width:                            16384
Max image 2D height:                           16384
Max image 3D width:                            2048
Max image 3D height:                           2048
Max image 3D depth:                            2048
Max samplers within kernel:                    480
Max size of kernel argument:                   3840
Alignment (bits) of base address:              1024
Minimum alignment (bytes) for any datatype:    128
Single precision floating point capability
  Denorms:                                     Yes
  Quiet NaNs:                                  Yes
  Round to nearest even:                       Yes
  Round to zero:                               No
  Round to +ve and infinity:                   No
  IEEE754-2008 fused multiply-add:             No
Cache type:                                    Read/Write
Cache line size:                               64
Cache size:                                    262144
Global memory size:                            8500232192
Constant buffer size:                          131072
Max number of constant args:                   480
Local memory type:                             Global
Local memory size:                             32768
Max pipe arguments:                            16
Max pipe active reservations:                  65535
Max pipe packet size:                          1024
Max global variable size:                      65536
Max global variable preferred total size:      65536
Max read/write image args:                     480
Max on device events:                          4294967295
Queue on device max size:                      4294967295
Max on device queues:                          4294967295
Queue on device preferred size:                4294967295
SVM capabilities:
  Coarse grain buffer:                         Yes
  Fine grain buffer:                           Yes
  Fine grain system:                           Yes
  Atomics:                                     Yes
Preferred platform atomic alignment:           64
Preferred global atomic alignment:             64
Preferred local atomic alignment:              0
Kernel Preferred work group size multiple:     128
Error correction support:                      0
Unified memory for Host and Device:            1
Profiling timer resolution:                    466
Device endianess:                              Little
Available:                                     Yes
Compiler available:                            Yes
Execution capabilities:
  Execute OpenCL kernels:                      Yes
  Execute native function:                     Yes
Queue on Host properties:
  Out-of-Order:                                Yes
  Profiling :                                  Yes
Queue on Device properties:
  Out-of-Order:                                Yes
  Profiling :                                  Yes
Platform ID:                                   000000EE22A01530
Name:                                          Intel(R) Core(TM) i5-5200U CPU
@ 2.20GHz
Vendor:                                        Intel(R) Corporation
Device OpenCL C version:                       OpenCL C 2.0
Driver version:                                5.2.0.10094
Profile:                                       FULL_PROFILE
Version:                                       OpenCL 2.0 (Build 10094)
Extensions:                                    cl_khr_icd cl_khr_global_int32_
base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomic
s cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth
_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_
dx9_media_sharing cl_intel_dx9_media_sharing cl_khr_d3d11_sharing cl_khr_gl_shar
ing cl_khr_fp64 cl_khr_image2d_from_buffer
Platform Name:                                 AMD Accelerated Parallel Proces
sing
Number of devices: 2
Device Type:                                   CL_DEVICE_TYPE_GPU
Vendor ID:                                     1002h
Board name:                                    AMD Radeon (TM) R5 M330
Device Topology:                               PCI[ B#4, D#0, F#0 ]
Max compute units:                             5
Max work items dimensions:                     3
  Max work items[0]:                           256
  Max work items[1]:                           256
  Max work items[2]:                           256
Max work group size:                           256
Preferred vector width char:                   4
Preferred vector width short:                  2
Native vector width char:                      4
Native vector width short:                     2
Native vector width int:                       1
Native vector width long:                      1
Native vector width float:                     1
Native vector width double:                    1
Max clock frequency:                           750Mhz
Address bits:                                  32
Max memory allocation:                         1409286144
Image support:                                 Yes
Max number of images read arguments:           128
Max number of images write arguments:          8
Max samplers within kernel:                    16
Max size of kernel argument:                   1024
Alignment (bits) of base address:              2048
  Denorms:                                     No
  Quiet NaNs:                                  Yes
  Round to zero:                               Yes
  Round to +ve and infinity:                   Yes
  IEEE754-2008 fused multiply-add:             Yes
Cache line size:                               64
Cache size:                                    16384
Global memory size:                            2147483648
Constant buffer size:                          65536
Max number of constant args:                   8
Local memory type:                             Scratchpad
Max pipe arguments:                            0
Max pipe active reservations:                  0
Max pipe packet size:                          0
Max global variable size:                      0
Max global variable preferred total size:      0
Max read/write image args:                     0
Max on device events:                          0
Queue on device max size:                      0
Max on device queues:                          0
Queue on device preferred size:                0
SVM capabilities:
  Coarse grain buffer:                         No
  Fine grain buffer:                           No
  Fine grain system:                           No
  Atomics:                                     No
Preferred platform atomic alignment:           0
Preferred global atomic alignment:             0
Kernel Preferred work group size multiple:     64
Unified memory for Host and Device:            0
Profiling timer resolution:                    1
Available:                                     Yes
  Execute native function:                     No
  Out-of-Order:                                No
  Profiling :                                  Yes
  Out-of-Order:                                No
  Profiling :                                  No
Platform ID:                                   00007FFF03500188
Vendor:                                        Advanced Micro Devices, Inc.
Device OpenCL C version:                       OpenCL C 1.2
Driver version:                                2348.4
Version:                                       OpenCL 1.2 AMD-APP (2348.4)
Extensions:                                    cl_khr_fp64 cl_amd_fp64 cl_khr_
global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int3
2_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_
khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store
cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd
_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_d3d10_sharing cl_khr_d3d11_sha
ring cl_khr_dx9_media_sharing cl_khr_image2d_from_buffer cl_khr_spir cl_khr_gl_e
vent cl_amd_liquid_flash
Device Type:                                   CL_DEVICE_TYPE_CPU
Vendor ID:                                     1002h
Board name:
Max compute units:                             4
  Max work items[0]:                           1024
  Max work items[1]:                           1024
  Max work items[2]:                           1024
Max work group size:                           1024
Preferred vector width char:                   16
Preferred vector width short:                  8
Preferred vector width int:                    4
Preferred vector width long:                   2
Preferred vector width float:                  8
Preferred vector width double:                 4
Native vector width char:                      16
Native vector width short:                     8
Native vector width int:                       4
Native vector width long:                      2
Max clock frequency:                           2195Mhz
Address bits:                                  64
Max memory allocation:                         2147483648
Image support:                                 Yes
Max number of images write arguments:          64
Max image 2D width:                            8192
Max image 2D height:                           8192
Max size of kernel argument:                   4096
  Denorms:                                     Yes
  Quiet NaNs:                                  Yes
  Round to zero:                               Yes
Cache line size:                               64
Cache size:                                    32768
Max pipe active reservations:                  16
Max pipe packet size:                          2147483648
Max global variable size:                      1879048192
Max global variable preferred total size:      1879048192
Max read/write image args:                     64
SVM capabilities:
  Atomics:                                     No
Available:                                     Yes
  Out-of-Order:                                No
  Profiling :                                  Yes
  Out-of-Order:                                No
  Profiling :                                  No
@ 2.20GHz
Vendor:                                        GenuineIntel
Driver version:                                2348.4 (sse2,avx)
cl_khr_gl_sharing cl_ext_device_fission cl_amd_device_attribute_query cl_amd_vec
3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_d3d10_sh
aring cl_khr_spir cl_khr_gl_event
C:\Users\User>
