hair disconnect/reconnect not working with modifiers #54488
6 Participants
Reference: blender/blender#54488
Linux (Arch), GTX 1080
2.79b
f4dc9f9d68
When using a hair particle system on an object with a mirror modifier, and trying to disconnect and then reconnect the hair the particle positions are messed up.
hair-mirror-2.blend
More Info
hair-mirror-4.blend
Added subscriber: @omgold
#67069 was marked as duplicate of this issue
Added subscriber: @brecht
The problem here is that the "Use Modifier Stack" setting is not properly taken into account for these disconnect/reconnect operators.
Added subscriber: @lichtwerk
Hi @brecht, @omgold, I've seen you discuss this on the mailinglist (and I understand reaching out here as for some reason this report seemed to slip under the radar)
But: why not continue here? This way others (including me) can follow and participate much better.
Sorry for the wall of text, but pasting from the mailinglist, so it doesnt get lost...
@lichtwerk Yes, of course. Sorry in case I failed to follow the preferred procedures. No secret that I'm rather new around here.
In any case, I looked further into the matter, and as psys_calc_dmcache() is just setting num_dmcache = DMCACHE_ISCHILD in the case of 'use modifier stack', I did this also, and voila stuff seems to work. Apparently the marker DMCACHE_ISCHILD is abused to handle the case of modifier stacks also. In case this reasoning is right, and you want to try, here is the fix:
0d6a3aaf87
I'm still trying to understand the wrong placement of hair after disconnect with subsurf and 'use modifier stack' disabled. I will let you know, if I can figure out more.
About the situation with subsurf and no 'use modfiier stack', not it is clearer to me. The reconnect in this case seems to work like this:
I guess the best way to solve this, would be to use the final mesh (after modifiers) in the first step. The problem that appears there, though, is that the index of the face the hair is attached to has to be giving on the original mesh. I couldn't find a method available to do that, so I didn't come up with a patch (yet). Basically what would be needed is the inverse of psys_particle_dm_face_lookup().
Added subscribers: @MarekHolly, @grosgood
Mirror modifier and hair disconnect/reconnect not working togetherto hair disconnect/reconnect not working with modifiersAdded subscriber: @JacquesLucke
It seems unlikely that someone will work on this before the new hair type is usable. Therefore, I'll reclassify this as known issue.
This issue was referenced by
a4171f4866
db9ddb8a45
5dedb39d44
