Undo with text editor and run script crashes blender
5820K GTX 970
Latest daily build
Text editor undo after run script can crash Blender
Crash line of code is in text.c - function txt_do_undo - line 2002
int op = text->undo_buf[text->undo_pos];
Reason looks to be that text->undo pos is negative here.
The test to check for a negative value is not made till later.
Possible code change....
int op;
int prev_flags;
unsigned int linep;
unsigned int uni_char;
unsigned int curln, selln;
unsigned short curc, selc;
unsigned short charp;
char *buf;
if (text->undo_pos < 0) {
	return;
Load file - press run script - do undo a couple of times
Vuk Gardašević (lijenstina) renamed this task from Undo with text editor and runs cript crashes blender to Undo with text editor and run script crashes blender.Apr 2 2018, 7:40 PM
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
Can confirm this [had to press "Run Script" twice before undo to trigger crash], suggested code change also makes sense at first sight, will doublecheck later...
Although I am sure the change will fix the crash. What I am unsure of (as I don't really know the code) is if calling the function txt_do_undo with text->undo_pos with a value of -1 is a code design feature of if it indicates something else is not right somewhere else.
This would be caused by recent undo restructuring, will look into it.
