Edge Crease is acting like Remove Doubles
Closed, InvalidPublic
Win7 64bit
Broken: 2.79
Open file, press CTRL+E, select Edge Crease, press 1 and ENTER -> see how vertex count dropped from 172 to 160 due to geometry merging.
It happens in this file, my attempts to append this object in another .blend do not reproduce it.
Philipp Oeser (lichtwerk) closed this task as Invalid.
You have AutoMerge Editing turned on (and because edge crease is a transform operation internally it will apply the merging...)
If you turn this off (or you tweak the crease e.g. in the N-Panel) this should all be fine...
My bad, thank you very much!
