Alembic Export of Metaball Particle System #54703
Reference: blender/blender#54703
Windows 10 64bit : Nvidia 1070
blender-2.79.0-git.eb6fe5f
Alembic Export of Metaball Particle System only contains a single frame of the mesh sequence
Create a particle system, use a metaball object as the particle instance, cache the physics and export to Alembic, import result.
Thanks.
Added subscriber: @FinbarrORiordan
Added subscriber: @Blendify
Thanks for the report but it would be helpful if you add a blend-file to the report that demonstrates the issue at hand.
Requested Files attached
Alembic.abc
Alembic Export.blend
Alembic Import.blend
Added subscribers: @dr.sybren, @lichtwerk
Afaik, blenders alembic exporter does not support particle dupli objects and only exports points. (see the manual )
For mesh objects you can use a particle instance modifier [that will export OK], but unfortunately this is not available for metaballs.
I would say this is a known limitation not a bug, and close this as archived, unless @dr.sybren has something to add here?
I agree that this is not a bug but a known limitation.
Thank you for your time anyway.
not sure it's the best place, but also added to TODO here
