Change of dimensions on multiple axis does not work via N panel
Windows 10 64b
GTX 750Ti
Broken: 2.79, Tried also on 2.8 26ee700
Worked: I think it never worked. I am not sure
You can change multiple number by click and drag down and than write number you want for all selected fields. It works also for all transforms in N panel in 3D view (i forgot ist name) expect for dimensions. It will just stay whatever it was before.
FYI: i tried on text for X and Y and it set Y dimension same as X one was. Not what wrote.
-Open defauld scene.
-select cube
-pres N
-select multiple "2" in dimension and write something else.
-after confirmation nothing will change.
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
quoting @Campbell Barton (campbellbarton) from D270:
re: Object.dimensions This is really a bug in blender, python devs also found this and complained that it doesnt work when setting values at once.
obj.dimensions = 1, 2, 3
... also gives same problem. the way its applies breaks setting multiple values at once.
Anyways, confirming for now, maybe Campbell can have a look? (just throw back at me and I'll do more investigations...)
The bug is still there in:
version: 2.80 (sub 21), branch: blender2.8, commit date: 2018-07-27 01:01, hash: b8ab2a84d32, type: Release
build date: 2018-07-27, 01:23:24
platform: Linux
Steps to reproduce:
  • open a new file, the default cube appears
  • go to edit mode
  • extrude one face of the cube
  • go back to object mode
  • C.object.dimensions are not updated
Even after ob.data.update() the dimensions are not updated
Thank you for the huge work you are doing.
I tried: C.object.bound_box[6][2]
After extruding the upper face of the cube this property is not updated as well.
Emanuele
